Any tyre pressure experts out there?
tonyg
Post by tonyg » Thu Aug 06, 2015 7:14 pm
The car is starting to loosen up now and I've come to the conclusion that the official tyre pressures are too hard (same as the last car).
I'll probably try the suggestion that Kayfur give me for the old car (23 front,25 rear).
I'm probably not a good enough driver to work out the best pressures by myself, but if i try what difference should i expect when increasing/lowering either (or both)?
any help appreciated
Tony.
Now with half an engine
graeme
Re: Any tyre pressure experts out there?
Post by graeme » Fri Aug 07, 2015 8:31 am
You can work it out yourself with a cheap infra-red thermometer.
Like this:
http://www.amazon.co.uk/Benetech-Profes ... hermometer
or this:
http://www.amazon.co.uk/Fluke-Intrinsic ... hermometer
Or something in between :)
Go for a spirited run, then take 3 temp readings across each tyre, inside, middle and outside. In an ideal perfect setup for the type of driving you just did, they should all match. If the middle is higher, you're over-inflated. If it's lower, you're under-inflated. If the inside is higher you're running too much +ve (EDIT: I mean -ve) camber (but that's normal for road use... nobody leans on the tyres that hard on public roads). If the outside is higher, you probably need the geo looked at.
The racers have more experience with this setup and can probably offer tips.
211
958
Post by mckeann » Fri Aug 07, 2015 9:19 am
graeme wrote:You can work it out yourself with a cheap infra-red thermometer.
Like this:
or this:
Go for a spirited run, then take 3 temp readings across each tyre, inside, middle and outside. In an ideal perfect setup for the type of driving you just did, they should all match. If the middle is higher, you're over-inflated. If it's lower, you're under-inflated. If the inside is higher you're running too much +ve camber (but that's normal for road use... nobody leans on the tyres that hard on public roads). If the outside is higher, you probably need the geo looked at.
Spot on, except I think you mean negative camber if the inside is hotter?????
graeme
Post by graeme » Fri Aug 07, 2015 9:29 am
Of course I did. I was just checking if you banged your head. :thumbsup
211
958
Post by alicrozier » Fri Aug 07, 2015 11:26 am
One slight modification (to take out camber effects and maybe more suitable for road driving) is to look for an even temperature gradient across the profile.
e.g.
65 60 55
65 65 55 = too much pressure
65 55 55 = too little pressure
None of this is 100% accurate and lots of other contributing factors but good enough to work to.
graeme
Post by graeme » Fri Aug 07, 2015 11:32 am
Oh, that's good Ali. I like that.
211
958
C7Steve
Post by C7Steve » Fri Aug 07, 2015 12:10 pm
alicrozier wrote:One slight modification (to take out camber effects and maybe more suitable for road driving) is to look for an even temperature gradient across the profile.
e.g.
65 60 55
Are you still taking it on the Frolic? :cheers
Steve.
Post by alicrozier » Fri Aug 07, 2015 12:48 pm
Yup, have infra red thermometer in my tool bag. All welcome to borrow.
C7Steve
Post by C7Steve » Fri Aug 07, 2015 1:42 pm
Getting excited now. :lol:
Steve.
martins
Post by martins » Fri Aug 07, 2015 2:36 pm
:chainsaw I will be putting in a protest to the Mods soon. :chainsaw
Every other thread on here seems to end up being hikacked by those going on FROLIC. :flame Please stop this as it continually reminds me that I am NOT going on FROLIC and instead have to stay in Aberdeen for reasons now unknown. I did suggest to HWMBO that I take Andy's spot . This was met with a death stare followed by a 5 minute lecture re daughter moving out, flat purchase, morgage to arrange and various other trivia.... :protest
All I have to look forward to is KH on 05 Sept when I will no doubt have to listen to all the stories about........you guessed it.....FROLIC.....
:mrgreen:
Mini Cooper (wife spec)
BMW dog wagon
Kinger
Post by Kinger » Fri Aug 07, 2015 9:29 pm
martins wrote::chainsaw I will be putting in a protest to the Mods soon. :chainsaw
:mrgreen:
Martin, I thought you were the boss. Give her a kiss on Thursday morning and say see you on the 24th.........Bye !! :D
martins
Post by martins » Fri Aug 07, 2015 9:55 pm
I was wondering how long it would take you to come along Kinger......tried the kiss and go before with work and it does not really work....I have however got a provisional kitchen pass for a week away in the car next year[THUMBS UP SIGN][THUMBS UP SIGN][THUMBS UP SIGN]
BMW dog wagon
tonyg
Post by tonyg » Tue Aug 25, 2015 4:00 pm
Back on topic :)
Thanks for the help guys.
I have to admit i was expecting something like if you go lower on the front it will oversteer/understeer more/less and affect the balance in this way, but it's about getting the tyres working correctly that's fine by me.
Post by Scotty C » Tue Aug 25, 2015 8:01 pm
I prefer to work on pressures when there hot. Because everyday is different. I've seen me using pressures as low as 22 when cold. This is mainly for track use but should also work out on road. Go out for a spirited blast and pull over and try your pressures.
gambler
Post by gambler » Wed Aug 26, 2015 9:47 am
Especially for track, get some heat into them and then adjust the pressures from there. For the road, i just make sure that they are round
S1 Elise - Shed spec
330d - Dog carrying spec
640d - Grown up spec
