Replacement fixings for clams?
SteveJB
Post by SteveJB » Wed Sep 02, 2015 10:13 pm
On removing the clams, many of the fixing broke and will need replaced.
Are there any fixing kits out there or any guides on what people have done. The bolts appear to have been kept in place by taps like so:
So when they break off leaving a rather large whole, they best I can think of is getting replacement taps(or whatever they are called) and weld the tap, bolt & a washer together then bold the washer to the car, then the clam can be bolted on from there.
Any comments/advice welcome
cheers
Steve
Re: Replacement fixings for clams?
Post by Ferg » Wed Sep 02, 2015 11:01 pm
Don't know about the fixings but change that boot opener while you have it all apart! :-)
whaleys
Post by whaleys » Thu Sep 03, 2015 9:11 am
Rivnuts?
TarmacTerrorist
Post by TarmacTerrorist » Thu Sep 03, 2015 5:14 pm
They are rivnuts.
Most good nut and bolt suppliers will stock them.
You ideally need a rivnut gun but you can pull them in with spacers and a bolt.
If you need to go even faster, just imagine you are me.
thinfourth
Post by thinfourth » Mon Sep 07, 2015 7:05 pm
Its a rivnut
2 rivnut guns here in aberdeen if anyone local needs to borrow one
