Plumbing/Fixings Help FALC
shooomer
Post by shooomer » Tue Oct 06, 2015 2:51 pm
Plastic drip tray below connects to drain via hose with male fixing at the yellow circle. Plastic has fatigued and threaded plastic cylinder at yellow circle has broken off. Any ideas how I can create a watertight drain hose from just a hole in the drip tray? Ideally I want a neat fixing like a plug hole rather rather silicone/gaff tape effort (hole is around 20mm dia) TIA, Paul
r10crw
Re: Plumbing/Fixings Help FALC
Post by r10crw » Tue Oct 06, 2015 3:08 pm
Just use a standard drain plug waste which will leave you with a standard 1'1/4 threaded fitting on the underside. It means opening the hole up to 32mm but thats no big deal??
http://www.screwfix.com/p/sprung-basin- ... tted/73414
Hairdresser at heart.
r10crw
Post by r10crw » Tue Oct 06, 2015 3:09 pm
PS Ive got a standard one I didnt use from my bathroom last week, you can have it for nothing. If u want it send me your addy
shooomer
Post by shooomer » Tue Oct 06, 2015 4:30 pm
:thumbsup Found a PE black tank connector after a bit of googling
Mods, this can be deleted
BigD
Post by BigD » Tue Oct 06, 2015 6:49 pm
Was just about to say tank connector as that's what they use to connect to water tanks etc. But you're sorted now. 8)
