S2 front wheel arch liners.
Post by tut » Sun Oct 11, 2015 3:07 pm
Anybody know if the S1 and S2 ones are the same as both of mine are damaged, missing.
Re: S2 front wheel arch liners.
Post by campbell » Sun Oct 11, 2015 3:52 pm
No chance, Tut. Entirely different clams.
Ready to stand corrected. As usual ;-)
Damaged, missing? Who's been running your car? Oh wait...!!
Post by mckeann » Sun Oct 11, 2015 4:11 pm
Not the same tut. They do wear out under heavy use, I wonder if they could be patched up???
Kinger
Post by Kinger » Sun Oct 11, 2015 4:33 pm
Tut,
My S2 Exige went through them at the front, I cut some Aluminum plate sealed and pop riveted them in to cover the hole. Made sure all surfaces were smooth so as not to cut tyre if it makes contact. No more wear and lasted while I had the car, that said I put nitrons on at the same time.
Post by tut » Sun Oct 11, 2015 4:34 pm
Will have to ask Clarky Neil as one is missing and the other is split in half.
There are a couple on eBay in good nick at £49, one is marked as LHD but that should not be different.
ps:- £47 new on deRoure, so not worth buying used ones.
