111R engine cleaning
- james.beaumont1
Hi guys. My 111R needs some engine bay tlc. The engine cover is tarnished (?) - can this be polished out? The car is booked in to be detailed but this won't be done and I'd like it looking as good as possible.
Re: 111R engine cleaning
I was looking at mine last night putting on the trickle charger and thought the same lol - keep me posted!
- james.beaumont1
Will do - still searching for an answer!
There was a thread somewhere a few months ago about the same issue with the plastic side air intakes.... something for peanut butter IIRC....
Found it! I assume the same tricks would work for the engine bay plastics...
http://www.scottishelises.com/phpbb/vie ... ut#p484829
- james.beaumont1
Handy thread mate but I was actually meaning the metal top of the engine!
Is it aluminium? That looks like aluminium oxide. Try a polish (such as Mothers Mag & Aluminium Polish) to remove the oxidized bits, then a good skoosh of ACF-50 to protect it.
211
958
958
- james.beaumont1
I have started working on it with Autosol as that's all I have just now but it's working very nicely. I'm now looking for an attachment (steel wool) for my drill to get to all the hard to reach places - any suggestions?graeme wrote:Is it aluminium? That looks like aluminium oxide. Try a polish (such as Mothers Mag & Aluminium Polish) to remove the oxidized bits, then a good skoosh of ACF-50 to protect it.
Autosol wil do nicely. Same stuff pretty much.
NOT steel wool though... jeezless cripes, you'll scratch the blazes out of it.
Try something like this? http://www.cleanyourcar.co.uk/polishing ... _1429.html
Out of stock there, but that kinda thing. https://www.google.co.uk/webhp?sourceid ... +for+drill
Use it with the Autosol as an abrasive and think about splatter before you start! Don't touch anything plastic. If in doubt, stick to using a cloth and elbow grease.
Most importantly, get the ACF-50 on asap afterwards.
211
958
958
Some after pics please.
- james.beaumont1
That's great advice- the attachment is exactly what I'm looking for - just wondering how to get right down in to the engine bay and get to the alternator etc without some serious dismantling!graeme wrote:Autosol wil do nicely. Same stuff pretty much.
If you can't reach it, you can't see it. Stop cleaning and drive the thing.
211
958
958
- james.beaumont1
Haha. It's in the garage for the winter so I'm having to find other ways to amuse myself!graeme wrote:If you can't reach it, you can't see it. Stop cleaning and drive the thing.
Callummarshall
It depends if it's just dirty, or if it's corroded. Looks like corrosion, so the more aggressive-ish method that Graeme talks about is the one to go for. Remember that ally holds up best when it's basically got a light layer of corrosion protecting the material (that's all anodising is) so polish it up to a shine and you'll be cleaning it weekly for ever more. ACF50 on a rag and wipe over halts existing corrosion and stops further happening - it's essentially just aerospace WD40 that lasts and clings a lot better.
The engine cover was designed to sit under a bonnet in the dry, not under slats that dribble water onto it - so unfortunately, it will end up looking a bit rough unless you get OCD about keeping on top of it.
