Avon ZZRs Delaminated
C7Steve
Post by C7Steve » Fri Mar 25, 2016 11:21 am
I decided to change my tyres back to the Pirellis for tomorrows trackday and noticed that both rear ZZR tyres have delaminated on the inside. The psi was at 25(cold) but obviously this is too low for the heavier V6 car. The next time that I have a set of these fitted, I will be running them on at least 30 to save this happening again :oops: Fronts are ok ,but rears are now binned. Bummer :(
Steve.
Re: Avon ZZRs Delaminated
Post by tut » Fri Mar 25, 2016 11:32 am
They would have been fine for the trackway Steve.
Kinger
Post by Kinger » Fri Mar 25, 2016 11:36 am
Hi Steve,
That seems to have happened to quite a few of us, I had two tyres do that all the way round the circumference. Doug had one that parted company I think.
It's a shame this happens so easily as they are a great tyre, but I was a bit pi--ed off at throwing away two tyres with nearly 4mm tread left. However as we were going to Spa i thought that the best option.
Post by Dominic » Fri Mar 25, 2016 11:58 am
tut wrote:They would have been fine for the trackway Steve.
Not sure I would be confident "leaning" on them on the road let alone the track. How old were the tyres?
BigD
Post by BigD » Fri Mar 25, 2016 12:07 pm
Definitely to do with low tyre pressures I reckon. 25psi is quite low for such a heavy car. Even on my Elise I run the rears at 29psi.
They are quite strong even when like that. Dougs went way past that to the point the canvas was showing and they still held together. :)
Post by tut » Fri Mar 25, 2016 12:12 pm
What I meant was that Steve would not notice. :damnfunny
C7Steve
Post by C7Steve » Fri Mar 25, 2016 1:38 pm
Bought for last years Frolic and thought that they would have done for a couple more trackdays at KH.
Steve.
Post by tut » Fri Mar 25, 2016 2:35 pm
They last forever on the Elise, so it must be the extra weight of the Exige.
Post by Mike Scib » Fri Mar 25, 2016 2:43 pm
Si had the same issue with his on the V6.
As for all the talk about how long they last, seem no different to AD08r's from comparing mine with BigD's ZZR's with us both having similar cars and driving styles.
ZZR's are better in the dry taking longer to go off were as the AD08r's are better in the wet from my experience.
BigD
Post by BigD » Fri Mar 25, 2016 2:52 pm
The zzr's are fine in the wet. It's the torrential downpours on the way home when they are pretty bald that's the issue. Also I couldn't get mine to go off at all.
Probably similar wear Mike but they do grip and last for dozens of track days which none of the other cut slicks will do.
I only took ad08's to spa in case it snowed. :)
Post by Lazydonkey » Fri Mar 25, 2016 3:36 pm
Mike Scib wrote:comparing mine with BigD's with us both having similar driving styles.
You're not going to take that D are you ?
BigD
Post by BigD » Fri Mar 25, 2016 4:11 pm
That's a very good point, how could I overlook that. Similar driving styles, I think not! :damnfunny
C7Steve
Post by C7Steve » Fri Mar 25, 2016 4:13 pm
Thanks for the comments and I only have myself to blame for not putting more air in the tyres. Avon site says minimum of 22psi but I reckon that I need to increase the rear to 30-35psi cold 'then reduce when hot'.
The ZZRs had done four trackdays at the Frolic last year, so it was worth it for that alone. Amazing tyre in the dry and will probably get another set of rears. I wonder if the 888r is available in Exige V6 sizes yet and how they compare to the ZZRs??
You live and learn.
Tut, Your right, I probably would not have noticed that my tyre had started to delaminate while driving, but I would much rather have it this way instead of it happening on the road or track with the chance of coming off and having an accident. In fact no, I would much rather have had enough air in the tyre in the first place. The Pirellis psi are 32front and 38rear so it seems obvious now that 25 in the rear is far too low.
Steve.
C7Steve
Post by C7Steve » Fri Mar 25, 2016 4:14 pm
Mike and D, looks like the two of you will have to sort it out tomorrow on track. :lol:
Steve.
Post by tut » Fri Mar 25, 2016 4:50 pm
Big differences in pressures, S1 N3 I used to run 19/21 on track which seems low but somebody recommended that to me.
S2 N3 I will start at 24/26 and see how that feels. I think that I have AO 48's on all round, I thought that there was an R on the end but mine don't have it.
