Lightweight Flywheel
pshanks76
Post by pshanks76 » Sun Apr 03, 2016 11:02 am
Anyone fitted a lightweight flywheel to a k-series? Was there a noticeable difference and any issues?
Cheers, Paul.
Elise S2 135r no more... Crossed to the dark side with a Boxster 981s
BMW 330D x-drive m-sport touring
Autosleeper Duetto camper
Re: Lightweight Flywheel
Post by Ferg » Sun Apr 03, 2016 11:58 am
VHPDs come with one as standard AFAIK.
fd
Post by fd » Sun Apr 03, 2016 12:00 pm
I wouldn't do it . . . having done it . . . If you have a tweaked engine it's idle control will have to be spot on if you don't want it stalling . . .
Fd
pshanks76
Post by pshanks76 » Sun Apr 03, 2016 12:57 pm
Cheers. The 135r isn't VHPD but I do have Piper cams fitted so the idle is slightly erratic so probably worth giving it a miss!
Post by BiggestNizzy » Sun Apr 03, 2016 11:24 pm
You stall it more, Engine rev's more freely but pulling away takes some getting used too.
Edited to add that from memory I have a 135 head with 135 cams with a 4-2-1 exhaust. I only did the flywheel because it was cheap and I was having a clutch fitted at the same time.
Post by mwmackenzie » Mon Apr 04, 2016 9:37 am
I had the one on my old S1 111s done by Stu160 and had no issues at all with it :thumbsup
Post by Dominic » Mon Apr 04, 2016 11:23 am
Depends how much is taken out of it - a little lightening will make little difference and not be too noticeable, a lot of lightening will make a bigger difference, and bring you the issues as mentioned above. Either way, I doubt I would bother. :thumbsup
Post by Corranga » Mon Apr 04, 2016 3:36 pm
I have one fitted. Engine seems more free revving and I've had no issues with stalling. I did fit it at the same time as a CR box and a new clutch though so hard to tell for sure what has made what difference!
