More photos on the gumtree ad
https://www.gumtree.com/p/cars-vans-mot ... 1177028331
Its a 2003 cherokee kj with the 2.5 diesel vm engine, 113k on the clock , mot until October.
Full leather interior in great condition
Heated seats ( both fully working)
Selectable 2wd, 4wd and 4wd low ratio.all of which are working and I test them briefly every month to stop anything seizing up
Air con .fully working
Roof rails and bars.
Tow bar - replaced under a jeep recall
CD player and tape deck ( Beatles bootleg tape available by seperate negotiation )
When I bought it I did a oil and filter change ( air fuel oil) and replaced the thermostat including coolant flush a few times. I also replaced the battery and alternator before discovering a wiring fault which is repaired ( original battery and alternator were probably fine but I've kept the replacements in). There is some service history from previous owner including work on the transfer box and welding on sills.
I put 4 new fallen fk 449 m&s tyres on it in Jan so loads of tread and no ditchfinders. Its also had the handbrake shoes and rear pads changed .
Generally its a solid reliable 4x4, getting about 30mpg and a good spec.
Downsides - rear heated windscreen doesn't work, there's a scratch on drivers door, the alloys look rough but are solid , the welding to sills wasn't painted well so surface rust was showing at two edges. I stripped it back etched it then used por15, could do with top coat.
1500ono
