Bridgestone Adrenalin RE002s
jammacdo
Post by jammacdo » Fri Jul 15, 2016 11:09 am
Guys
I need to replace my worn AD08s on the back of S2. They haven't exactly lasted very long and thats with normal driving and only a standard K series engine. So thought I'd try something new so have ordered the Bridgestones above. They are supposed to be for enthusiastic driving and recommended for small lightweight hot hatches so cant be too wrong for the Elise. Blackcircles just called me to "warn" me they might not be suitable but they are just covering their arse and don't actually know what the issues might be.
Any real problem with doing this? I see lots of people using tyres that are not the AD07/8s and given that I didn't notice any difference between AD07's and AD08's I thought this would be reasonable. The alternative is to spend another 70 quid for something I might not even notice.
Thoughts (before its too late to cancel) 8)
captain
Re: Bridgestone Adrenalin RE002s
Post by captain » Fri Jul 15, 2016 12:09 pm
Can you get them in the right size for the front too?
Post by Shug » Fri Jul 15, 2016 12:14 pm
Generally a really poor idea to put something that's potentially going to have lower grip on the rear first. Never heard of the RE002s but the OE fitment for early Elises was a Bridgestone RE080 (IIRC) and it did not have the grip of the Yoko and certainly not in the wet.
Would not want to be entering a wet roundabout backwards because the rears performed completely differently to the fronts...
Just my 2c on it - Elise is more sensitive to tyres than just about anything else on the road.
Post by Stephen » Fri Jul 15, 2016 12:19 pm
I would stick with Yokohama
jammacdo
Post by jammacdo » Fri Jul 15, 2016 12:27 pm
Arghhh ok will cancel. Would love to be able to compare these tyres but for 70 quid and a bit more hassle I better stick with the tried and tested AD08's
thanks guys :)
jammacdo
Post by jammacdo » Fri Jul 15, 2016 12:28 pm
captain wrote:Can you get them in the right size for the front too?
no :( and anyway, I've just replaced the fronts with AD07's for the MOT about 1000 miles ago.
Post by Mike Scib » Fri Jul 15, 2016 12:48 pm
How long did your rear AD08's last?
Post by j2 lot » Fri Jul 15, 2016 1:13 pm
A sensible decision. The Elise is probably the most sensitive car when it comes to set up and for cost of a couple of tanks of fuel its worth the extra expense to be on the safe side. if you were sitting in a ditch facing the wrong way you would be cursing saving a few quid :blackeye
jammacdo
Post by jammacdo » Fri Jul 15, 2016 2:46 pm
Mike Scib wrote:How long did your rear AD08's last?
Less than 5000 miles! And thats no wheelspins.
Post by Stephen » Fri Jul 15, 2016 3:02 pm
Did you have bricks in the boot? [FACE WITH TEARS OF JOY]
Post by Mike Scib » Fri Jul 15, 2016 3:19 pm
Sounds like you need your tracking looked at tbh.
Mine have lasted 6-7000 miles including a good few track days!
No wheelspins here either......
Post by DDtB » Fri Jul 15, 2016 3:27 pm
And Mike's isn't exactly a standard car either... it's 260+ bhps
Maybe a geo is in order? How did the tyres wear... evenly? outside/inside etc?
jammacdo
Post by jammacdo » Fri Jul 15, 2016 4:51 pm
DDtB wrote:And Mike's isn't exactly a standard car either... it's 260+ bhps
Tyres seem evenly worn and I've had the geo setup and checked. Mind you I wasn't 100% happy as Redpath Tyres in Edinburgh never managed to get my steering wheel straight when doing the setup. Is there any better place to get 4 wheel geo done?
rawsco
Post by rawsco » Sat Jul 16, 2016 7:53 am
I managed 4000 out a set of A048 and they only have 5 or 6mm or tread when new so your mileage seems low. Have done 3 track days and a walshy day on my AD08r tyres and still plenty of tread left. Probably 2000 road miles on them too.
Rawsco
2021 - Tesla M3LR
2019 - Exige 410
Post by campbell » Sat Jul 16, 2016 11:57 am
Been Toyo for me for years. Prob AD08's next tho. Usually get 10k+ out of rears.
