Front coolant bleed point
Post by Ferg » Sat Oct 22, 2016 5:19 pm
Replaced both the temp sensors today and bled the coolant at the front bleed point. The bleed point wasn't overly clever at resealing. :( If I push the hose it sprays a little but is ok when left alone. Is this likely to fail imminently? Can a new hose be done with the clam on?
Re: Front coolant bleed point
Post by Dominic » Sat Oct 22, 2016 9:23 pm
Don't think I would want to chance it. I think there would be sufficient access to change the hose with the wheel arch liner out but the clam on. Might be a bit footery though. I would await the experts though.
Post by Mike Scib » Sun Oct 23, 2016 9:11 am
Is the insert into the hose turning Ferg? In the past I have put a Jubilee Clip around it but not ideal due the heat/pressures on track!
If its not the insert, is the rubber O' ring still there....
Post by Ferg » Sun Oct 23, 2016 12:17 pm
Mike Scib wrote:Is the insert into the hose turning Ferg? In the past I have put a Jubilee Clip around it but not ideal due the heat/pressures on track!
I'm worried it's the insert hence why I'm wondering if I can do hose without clam off. I didn't know there was a rubber o-ring ring in there too. :oops: Will have a look but my money is on the insert.
Post by Corranga » Mon Oct 24, 2016 8:21 pm
I did our vx220 front rad hose (same part) with the clam on.
Arch liner out, front under tray off and headlight out.
Having done the S1 with the clam off, I think it would be possible I a similar way..
Chris
Post by Ferg » Mon Oct 24, 2016 9:27 pm
Corranga wrote:I did our vx220 front rad hose (same part) with the clam on.
Chris
Had a look today. Fitted a precautionary jubilee clip but it looks like it should be doable with the arch liner out. :thumbsup
