Engine Oil - VHPD
Evoman
Engine Oil - VHPD
Post by Evoman » Thu Nov 03, 2016 11:49 am
I've tried using the search function but haven't come up with much.
The Lotus handbook states 10W/60 or 15W/50.
I realise things move on with oils but would be interested to hear what folks would recommend for the VHPD?
Cheers!
Re: Engine Oil - VHPD
Post by Dominic » Thu Nov 03, 2016 12:06 pm
Mine is not VHPD, but I use this stuff (usually I buy 5l, but can't see that on Opie's website); http://www.opieoils.co.uk/search/go?lbc ... nd%3afuchs
Fuchs Titan Race Pro S 10W-50 Ester Fully Synthetic Engine Oil -5 Litres
Post by Victor Meldrew » Thu Nov 03, 2016 12:15 pm
Cannot remember the viscosity but I used a Millar oi.
I remember it was red in colour that would turn a lovely milkshake pink when the dreaded HGF happened. It was more susceptible to water absorption and had to be changed every 6k. I think the manufacturer changed the branding at one point. Someone else will remember the type based on the "RED" color
Evoman
Post by Evoman » Thu Nov 03, 2016 12:30 pm
Thanks guys, looking at Opie Oils for options.
UncleRon
Post by UncleRon » Thu Nov 03, 2016 12:36 pm
I agree with Dom and that is a great spec of oil but it is quite pricey.
I usually go for the PETRONAS Syntium Racer X1 Fully Synthetic version of this which is a 10w 60 oil and comes up on offer for £27 for 4 litres with Euro Car Parts from time to time. I think it's about £30 for 4 litres delivered with car parts for less which is a ECP subsidiary just now.
Post by Ferg » Thu Nov 03, 2016 1:02 pm
Having used various I settled on using the Fuchs Titan stuff from Opie. :thumbsup
Post by mwmackenzie » Thu Nov 03, 2016 6:55 pm
Would treacle not be best in there?? I believe Castrol do a 10/60 as do Gulf, my mate used it in his M3, 15/50 do Mobil motorsport not do this?
hiscot
Post by hiscot » Fri Nov 04, 2016 9:05 pm
mwmackenzie wrote:Would treacle not be best in there?? I believe Castrol do a 10/60 as do Gulf, my mate used it in his M3, 15/50 do Mobil motorsport not do this?
Castrol do a high sheer rate 10/60 designed for BMW because the m5 used to throw rods hence the Castrol oil
It's what I use with the turbo k series after advice from an oil tec
bob
Post by Ferg » Sat Nov 05, 2016 11:32 am
The 60 temp rating is important for turbo cars. For the VHPD either 50 or 60 should be fine. :)
hiscot
Post by hiscot » Sat Nov 05, 2016 12:01 pm
The oil I use has a very high sheer rate with a HTHs of around 5.3 cp
typical 5/40 oil can be around 3.5 cp with low friction economy oils having around 2.9 cp
The high sheer rate is for bearing protection .On my TM supermoto the shear rate (rock oil xrp ) l use is 7.0cp again in a 10/60 ,
bob
Post by Mr Momo » Sat Nov 05, 2016 6:29 pm
I seem to remember using Comma Motorsport in the Toxic Frog. Alan will be able to confirm if it stopped wear/bearing failure.... 8)
Emira - Volvo spec
Post by Ferg » Sat Nov 05, 2016 7:02 pm
There's a great review of oil by David with his Duratec. I actually changed manufacturer after some of his findings. It's in the search day somewhere... :-)
Post by campbell » Sun Nov 06, 2016 10:52 pm
I used Mobil 1 0w40 for years. No idea what's in it now!!!
Post by Ferg » Mon Nov 07, 2016 9:01 am
Worth noting that 10w40 is what the manual specifies for a standard K. Richard is correct that the manual for the VHPD states 10w60 or 15w50. :)
scott.a
Post by scott.a » Thu Feb 02, 2017 12:56 pm
Bit of a bump but im looking to drop the oil before the next trackday im doing on the 25th. Standard K-series with the PTP140 kit on it. The Fuchs Titan stuff looks like a good shout but im not sure what viscosity i should go with.
Thoughts?
ETA - Opie oils recomends http://www.opieoils.co.uk/pv-148559-fuc ... mentNotes=
