Whats the best thing to cover up some rusty grills? I'll have Craig do a proper job on it before winter but I just need something to stop it looking so tatty atm!
Another thumbs up for hammerite. I wire brushed the grills first, then used a "smooth finish" hammerite spray can. Quick and easy and gave good results. Did several thin layers of spray on paint.
I did the full buna on the Elise, nitromors then rust treatment then paint. Rears remained good but the front still needed redone after 18 months. So next time I'd just wire brush and paint.
The thing I found most lasting was PlastiDip. Just gave them a good clean and sprayed on. Plus you can play with it on other things like the diffuser and worse case scenario you just peel it off
Update: slapped it on at the weekend, looks decent, certainly an improvement.
It will at least prevent the embarrassment of my rusty grills until I can be arsed doing it properly (spoiler: i'll never be arsed, I'll just give it to Craig )
