S1 Elise Motorsport replica project
stratosboy
Re: S1 Elise Motorsport replica project
Post by stratosboy » Fri Nov 30, 2018 11:27 pm
well, a Friday night glass of gin & tonic reply,
this conversion is a well trodden path and I have been advised by someone who has been involved in these for a while.
Pro-Alloy do have an Audi exige kit for things like charge cooler, baffled sump, rads and fuel tanks etc
I am however coming to the end of my skills as soon as it is plumbed in, as I then need all the electrical work doing.
I have enjoyed it though
Post by Ferg » Sat Dec 01, 2018 12:13 pm
stratosboy
Post by stratosboy » Sat Dec 01, 2018 4:48 pm
campbell wrote:
Fri Nov 30, 2018 10:20 pm
Worrying about you getting the clam back on!
no probs Campbell, plenty of room:
Post by campbell » Sat Dec 01, 2018 8:37 pm
That's great. Room for a suitcase in there!
stratosboy
Post by stratosboy » Sun Dec 02, 2018 12:59 am
erm...no!
mongo81
Post by mongo81 » Fri Jan 25, 2019 11:13 am
Excellent build Stratosboy. Would a standard cowl fit over the engine?
stratosboy
Post by stratosboy » Fri Jan 25, 2019 5:46 pm
Thanks Mongo, do you mean an Elise s1 engine cover? - then yes as things are currently, but I have yet to fit the bulkhead and tanks to the bulkhead which would prevent an elise engine cover/cowl fitting.
Some people have put these engines into standard elise body shell so it is do-able. obviously I have a bit more room with Exige clam.
mongo81
Post by mongo81 » Sat Jan 26, 2019 11:35 am
Yep s1 cover. In my ideal world my car will look as close to standard as possible
stratosboy
Post by stratosboy » Mon Jan 28, 2019 6:04 pm
brackets for Handbrake (Hi Spek) spot calipers machined - and can now be fitted. I have a spare which I used as a template if anyone wants to borrow it if planning to do this.
fitted to hub:
Post by Ferg » Thu Feb 07, 2019 9:59 am
Lovely big chargecooler! Are you running the related air/water coolers sandwiched at the front with the radiator? ...or something different. Great build 👍
stratosboy
Post by stratosboy » Fri Feb 08, 2019 4:57 pm
Thanks Ferg.
Yes I have a slim chargecooler rad underneath main coolant rad with sucker fans on top. All provided by Pro Alloy, great kit. You can see it at the bottom in this pic, the tubes with blue rubber glove fingers are the feed/return for the Chargecooler, now need to route the pipes through the NS sill.
Its amazing that it all fits withing the std S1 rad shroud.
Post by campbell » Fri Feb 08, 2019 7:58 pm
That would be enough to aircon our house
Post by Shug » Fri Mar 01, 2019 10:00 am
Brilliant build thread. This looks, if you'll excuse the french, like a f*cking weapon!
1999 Honda VFR800
Freestyling on the buckled wheel of life.
stratosboy
Post by stratosboy » Mon Mar 04, 2019 11:29 pm
cheers Shug, should be when it's finished! - still fettling bodywork at the moment.
stratosboy
Post by stratosboy » Fri Mar 22, 2019 10:23 pm
bodywork fettled, ready for paint.....next time you see it - will be blue!
