issue logging on with Iphone
Post by mckeann » Fri Jan 03, 2020 12:35 pm
reset passwords, have no issues logging on with laptop on chrome, but cannot login with iphone on Safari. Just downloaded Chrome to the iphone and it lets me login with that but i cba using a different browser just for SE.
Anybody else suffering with the same issues and has a fix?
Re: issue logging on with Iphone
Post by woody » Fri Jan 03, 2020 1:56 pm
Ddtb can't get logged in, don't know the actual issue though
Post by ed » Fri Jan 03, 2020 3:41 pm
I use Chrome on my iphone and it works fine, is the issue caused by Tapatalk perhaps?
C7Steve
Post by C7Steve » Fri Jan 03, 2020 5:07 pm
Mike Stout is having problems logging in too.
Steve.
Post by mckeann » Fri Jan 03, 2020 5:27 pm
I’ve never used tapatalk. Works ok on chrome, but when I try to login with safari it just says “the submitted form was invalid, please try again”
Post by robin » Fri Jan 03, 2020 9:45 pm
If you know how to forget all cookies for a site, that works - if you don't know how to do that (or if iOS Safari doesn't have that facility) then you'll need to forget your browser history (note: you'll then have to log in to all sites again). To see if this is the issue, login using a private browsing window (without forgetting any history) and see if it works - if it does, then the above is the right fix. I had to do it twice in quick succession (it worked, then stopped again), but not since.
rawsco
Post by rawsco » Sat Jan 04, 2020 1:39 am
Similar weirdness here has been for a while. As robin says I initially thought cookies but I get the same issues in balaclava mode. Faffing with it and going to the root url as opposed to my favourites linked to new posts etc seems to work around it for now. From a techie perspective it seems similar (I don‘t think it’s this it just feels similar)to when a load balancer sends you to a server that is unaware/unable to validate your session cookie and then asked and errors on log in as the session handler thinks you are logged in already. The error I get is the submitted form is invalid or something to that effect. Sometimes I can log in browse a few pages then get that error again. I don’t know enough about the set up to trouble shoot but summat is wonky!
Rawsco
2021 - Tesla M3LR
2019 - Exige 410
Post by robin » Sat Jan 04, 2020 6:45 pm
I'll see if Simon has any ideas ..
Post by mckeann » Sat Jan 04, 2020 11:47 pm
Worked fine in private window, cheers, will try the cookie delete
Post by robin » Sun Jan 05, 2020 1:36 am
Fingers crossed :-)
Post by mckeann » Sun Jan 05, 2020 12:00 pm
Still appears to be working ok this morning after a cookie delete, thanks Robin :thumbsup
Post by robin » Sun Jan 05, 2020 9:44 pm
Welcome - but don't be surprised if for some reason you need to do it again ... that's what happened to me. I am sure it was triggered by a Safari update on the Mac, but that could be a coincidence.
