Pressure Gauge Repairs
111Robin
Post by 111Robin » Mon Aug 17, 2020 2:47 pm
Does anyone know of someone in the Aberdeen area who could look at and repair a small pressure gauge ?. The gauge works but the needle doesn't return to zero. Not looking for pin point accuracy I just need it to work and be within +/- 50psi if possible. Don't want to approach the big companies up here as it's not worth much but I would like to repair rather than replace it.
111Robin
Re: Pressure Gauge Repairs
Post by 111Robin » Mon Aug 17, 2020 2:48 pm
PS. Doesn't really need to be in the Aberdeen area, anywhere I can post it to is fine as well.
Post by Mikie711 » Tue Aug 18, 2020 3:17 am
Probably cost more to repair and recalibrate a small gauge. The process is the same regardless of the size and accuracy of a gauge.
Correct or reset zero
adjust for span
check for scale
calibrate
on a small 2" gauge span and scale aren't always adjustable so the gauge is junk but you would still pay the inspection cost. Better to just bin it and buy a new one.They only cost £15-20.
BMW M2 Comp
BMW R1300GS
DJ
Post by DJ » Tue Aug 18, 2020 10:22 am
I'm curious .... what are you using it for and what sort of pressures are you recording that a +/- 50 psi tolerance is fine! Something industrial?
'03 Elise 111S - Sold :(
'55 Boxster S - Sold :(
'08 Exige S 240PP - Sold :(
'10 Evora NA - Sold :(
'12 Cayman R - Sold :(
'22 Alpine A110 :)
111Robin
Post by 111Robin » Tue Aug 18, 2020 2:31 pm
It's a hydrolastic pump I've restored. Gauge reads up to 400psi however the suspension pressures are usually around 350psi but normally set to a height as opposed to pressure. Maybe +/- 10psi is more realistic, but as I say normally it is set to the height not pressure.
Image20200817_161028 by Robin Derrick, on Flickr
DJ
Post by DJ » Tue Aug 18, 2020 5:42 pm
Ahh interesting. Thanks for posting pic. :thumbsup
'22 Alpine A110 :)
111Robin
Post by 111Robin » Tue Aug 18, 2020 6:00 pm
I don't really want to fit a modern gauge if possible hence the preference for fixing the existing one.
