Which V6 Brake Pads?
Post by Ferg » Wed Sep 09, 2020 6:22 pm
I've replaced a couple of sets of the standard Ferrodo pads and was thinking of changing.
I was a big fan of CL5+ on my S1 Elise and Exige so those are at the top of the list, but there are a number of other options. What are people using? For use on road and track.
BigD
Re: Which V6 Brake Pads?
Post by BigD » Wed Sep 09, 2020 7:10 pm
Ferodo ds1.11. Awesome pads and as it happens I have a heavily discounted new set for sale.
They last so long that I didn’t need to use them. Also have a half worn rear set.
Post by alicrozier » Wed Sep 09, 2020 9:51 pm
Performance Friction 08 (3-Eleven is the same).
https://www.elise-shop.com/performance- ... 2f67822866
C7Steve
Post by C7Steve » Thu Sep 10, 2020 6:20 am
Just fitted these and really impressed with them. :D
https://www.seriouslylotus.com/braking/ ... s29-yellow
Steve.
C7Steve
Post by C7Steve » Thu Sep 10, 2020 10:38 am
http://www.pagidracing.com/en/products/ ... sl-29.html
I have heard that the Performance Friction 08 Brake dust set like cement once wet onto the wheel rims, but maybe Ali C can comment.
There is a few threads on the Lotus Forums if you search.
https://www.thelotusforums.com/forums/t ... rake-pads/
Steve.
Post by Ferg » Tue Sep 15, 2020 8:19 pm
Worth saying that any Carbon Ceramic compound creates nasty results on your wheels in some way. Looks like there are several options, all with a downside. Whether it be corrosive dust, or disk abrasion, or something else. I suppose there's always a compromise with performance.
Decided against CL due to the disk wear reported. Big D is a fan of the DS1.11 which almost has me convinced. Performance friction are widely rated. Decisions decisions
neil
Post by neil » Fri Sep 18, 2020 9:02 am
Which discs are you using them with? Standard discs don't seem to work well with the more aggressive pads - I had issues with pad transfer
Exige V6
Post by Ferg » Fri Sep 18, 2020 8:03 pm
Yeah, they're std but I don't have budget for alloy bells just now.
I remember you having issues at Spa. Did you have the same issue again?
neil
Post by neil » Fri Sep 18, 2020 8:15 pm
It was CL pads I had issues with at Spa. Got them changed for what was meant to be standard but turned out to be Pagid Black and had the same problem. Changed back to standard and no issues since. I'm now running the Elise shop bells and rotors which are cheaper than standard discs so tempted to try more aggressive pads again if I ever get near a track.
Exige V6
Post by Ferg » Fri Sep 18, 2020 11:24 pm
The ES setup is attractive. Beyond that budget I'd want to up the diameter and reduce the heated fort going on. Dreaming though.
On the S1s I was a major CL fan, but for the V6 I think needs something else.
neil
Post by neil » Sat Sep 19, 2020 4:56 pm
The bigger diameter discs do look good. Just not sure there's much need other than for bling value. I must be getting old! :D
Exige V6
Post by Ferg » Tue Sep 22, 2020 3:22 pm
I'm thinking they are only really good for lower temps and therefore disk and pad life.
C7Steve
Post by C7Steve » Tue Sep 22, 2020 6:43 pm
I have the 343mm big brake front and rear kit from Seriously Lotus along with the Pagid RS29 yellow endurance pad and I am really impressed by it all so far. Looking forward to seeing how they perform on track hopefully soon. I called Dave from SL after a few weeks of use to let him know how impressed I was with his product and he burst out laughing saying, “if you think that they are good now, wait until you get your car on track and get some heat into the pads and then you will be even more impressed”.
I will report back after the Anglesey, Oulton, Cadwell trip hopefully next month.
I didn’t buy them for the bling. It was just that my discs required replacing and I really fancied one of the upgraded sets to see how much better they were. They do look good though.
Steve.
neil
Post by neil » Tue Sep 22, 2020 6:49 pm
:damnfunny :damnfunny :damnfunny :damnfunny We all believe you :damnfunny
Exige V6
C7Steve
Post by C7Steve » Tue Sep 22, 2020 7:57 pm
:damnfunny :finger
Steve.
