S1 Elise Toe links / rod ends
My outer has just snapped off.
Is there a cross ref part number or used on a other vehicle so i can possibly get quickly from the local motor factors?
Inner and outers if you have make / model / number
Fraser
Fraser
Re: S1 Elise Toe links / rod ends
Ok, looks like these are 'specials' for the Elise. But happy to be corrected
Just ordered a set from EP.
Fraser
Fraser
They are specials, but you are better off changing them for standard rose joints.
It's not nice when they go on you!
Interesting when i removed the old snapped joint, the ball joint was almost solid. Probable failure was fatigue since all the force was transferred to the arm.
That's what happens.
The ball seizes and the metal fatigues. It's worth reaching underneath and giving the bar a twist regularly.
Agreed. Its a good heads-up for others.
I will get rose-joints the next time round
I purchased standard rose joints and a track rod from McGill Motorsport.
Part Qty Price ea Total
2x M12 Male LH Rose Joint ULTRA HIGH STRENGTH /PERFORMANCE 2 £11.75 £23.50
2 x M12 Male Rose Joint Right Hand Thread ULTRA HIGH STRENGTH /PERFORMANCE 2 £11.75 £23.50
2 x Turnbuckle M12 12mm Link Adjustable from 360mm to 390mm (check the length it might be 292mm) 2 £10.80 £21.60
4 x M12 to M10 Rose Joint Reducer Top Hat Spacer (x2) (total of 8 - 2 per rose joint and 4 joints total) 4 £4.00 £16.00
4 x Sealing Boot for 3/8" or 7/16" Male or Female Rose Joint Rod End Dust Boot 4 £3.90 £15.60
£100.20
M12 x 1.75 mm left hand Half Nuts / Lock Nuts - Pack of 10 1 £5.00 £5.00
M12 x 1.75 mm right hand Half Nuts, rose joint - Pack of 10 1 £5.00 £5.00
£110.20
£100.20
£110.20
or you could just order the elise parts kit that has everything you need.
https://www.eliseparts.com/shop/steerin ... -link-kit/
It is worth considering the update to the EP links. There are other options like Spitfire too.
But whatever you do. Don’t neglect them
