by rossybee » Sat Sep 07, 2024 11:42 am
So having got the car back Thursday from CV boot replacement it's now not starting.
Am I right in saying the coil pack is mounted at the rear of the engine (RHS) under the inlet manifold?
Could the sprayed out grease from the old split CV boot onto the coil pack be the cause of not starting?
Is a coil pack an easy to change part (thinking access)
TIA
2004 Bentley Conti GT
Now browsing the tech pages
Kinger
by Kinger » Sat Sep 07, 2024 6:12 pm
Hi Ross,
I’ve just changed mine, my car has a single coil. Some of the vvc cars have two coils. It was a bit of a pain getting access, I had to remove the flexi pipe from the exhaust to gain access. You can only get to it from underneath a pain but easily do able, it’s only held in place by three bolts.
by Stephen » Sat Sep 07, 2024 8:19 pm
I'd check the earth
by woody » Sat Sep 07, 2024 11:09 pm
And I'd check the fuel shut off valve.
Think it's unlikely CV grease will have affected the coil tbh.
What symptoms do you have? Is it turning over and not firing? Have you checked for a spark?
by rossybee » Sun Sep 08, 2024 9:24 am
Kinger wrote: ↑Sat Sep 07, 2024 6:12 pm
Hi Ross,
Thanks Kinger
Stephen wrote: ↑Sat Sep 07, 2024 8:19 pm
I'd check the earth
Where would this be, cheers
by rossybee » Sun Sep 08, 2024 9:26 am
woody wrote: ↑Sat Sep 07, 2024 11:09 pm
Fuel pump priming, engine turning over, can smell fuel.
basil
by basil » Sun Sep 08, 2024 2:38 pm
Most likely the battery is too weak so try jump starting it and if that fails try bypassing the imobiliser. These are the two things that have prevented mine from starting in the past.
by Stephen » Sun Sep 08, 2024 10:11 pm
There's an earth strap between the gearbox and the passenger side longeron
by rossybee » Sun Sep 08, 2024 10:58 pm
Stephen wrote: ↑Sun Sep 08, 2024 10:11 pm
Cheers Stephen - best accessed from top (removing air box) or bottom (removing rear undertray)?
by Stephen » Sun Sep 08, 2024 11:04 pm
Bottom removing the undertray
by rossybee » Sun Sep 08, 2024 11:06 pm
Much appreciated
by woody » Mon Sep 09, 2024 5:19 pm
Also worth checking all the HT system if there's no spark. I had bother various times with the dizzy cap & rotor arm and a dodgy set of brand new Bosch leads.
by rossybee » Fri Sep 13, 2024 4:31 pm
OK so just had the AA man out (might as well) and he's been through it and recommends new plugs and possibly a dizzy cap.
Battery is strong, and fuel is definitely getting through.
Plugs are a minefield - S160 supplement says Champion RC9 but anything online says NGK - PFR6N-11 seem to figure when I search. Can anyone please confirm if this is correct?
And dizzy cap - just a std K series one?
Thanks in advance
by Stephen » Fri Sep 13, 2024 5:32 pm
Did the AA man get it to start?
Pretty much the same plug but different brand. The Dizzy cap is standard rover. If you are getting a cap, get a new rotor arm too.
Have you checked the plug holes in the head are not full of water?
S
