Julien
by Julien » Sat Mar 07, 2026 4:41 pm
Hello,
The right electric window has stopped working. After testing, there's no power at the switch; a wire is broken inside the rubber boot.
Is there an easily accessible connector to disconnect the wiring harness and remove the door panel if necessary?
Thank you for your help.
Julien
by Julien » Mon Mar 09, 2026 3:51 pm
I just find this on the Internet :
I hope i can access to the cut wire inside the boot to make a connection.
by campbell » Fri Mar 13, 2026 9:05 am
Good luck Julien!
We fixed a broken wire for our VW T5 camper in a similar situation
Julien
by Julien » Sun Mar 15, 2026 8:38 pm
Bad news, the connector was not here.
But we succed to reconnect the wire
by campbell » Sun Mar 15, 2026 11:43 pm
Working windows again then
