Which Pagids?
Novice Racer
Which Pagids?
Post by Novice Racer » Fri Apr 06, 2007 10:42 am
2002 S2, looking to upgrade pads for road and some track use this summer.
Want Pagids but unsure whether to go for the RS 4-2 or RS14.
Suggestions?
NR
Ipsa scientia potestas est
S2 Elise
Post by campbell » Fri Apr 06, 2007 10:53 am
RS4-2. Work fine from cold and need only slight warming to be brilliant.
RS1-4 are poorer from cold and need roasted to work right.
For your needs - v similar to mine - RS4-2 is the way.
Others will come along and mention other manufacturers too, though. But I've been a Pagid fan for 6 years :-)
Post by mac » Fri Apr 06, 2007 10:54 am
If what Campbell says = blue ones then :thumbsup
Mac :D
Post by campbell » Fri Apr 06, 2007 11:27 am
Er, yeah I think they are blue...but then I thought ALL Pagids were blue ;-)
Post by Andy G » Fri Apr 06, 2007 11:43 am
Hi NR
Go for the 4-2's.
They were awesome on my 111r - RS14's are more suited to heavy track use.
Post by robin » Sat Apr 07, 2007 8:04 am
You can get 95% the same performance from a set of SBS pro which are a fair bit cheaper (and come in a nice fetching bronze to boot).
If the only track you plan on driving is KH, then I would go for the SBS (I have them on EGOR (courtesy of Gareth)) and I think they're pretty good, and they get better when hot.
But I think they fade a bit under really high speed braking (not an issue at KH, but noticed it at Spa (130+mph braking down to about 60) - though that could also be a fluid problem, so cannot be sure.
Anyway, I bought two complete sets of RS4-2s in the last group buy, so that's what I will be fitting for the next year or two :-)
Post by mckeann » Sat Apr 07, 2007 8:44 am
42's for the road and occasional trackday.
14's are overkill unless you run sticky tyres on track.
Post by ed » Sat Apr 07, 2007 9:45 am
campbell wrote:Er, yeah I think they are blue...but then I thought ALL Pagids were blue ;-)
Nah the 14s are black iirc...
