by Shug » Fri Jun 29, 2007 2:26 pm
Okay, hands up - who knows for sure what they are off. I need to replace mine (after 2 snapping at the Dukes Pass last night
by Rich H » Fri Jun 29, 2007 2:33 pm
A Lotus Elise, talk to Lotus.
HTH
(Probably parts bin parts. Try Rover MGF??)
by woody » Fri Jun 29, 2007 4:42 pm
The IPC i have only gives P/N's for the hub assembly, not the studs i'm afraid. They should surely be able to do them seperatly though. Chances are they're Rover as the wheels nuts are.
I'm have a good excuse for the gheyness earlier, honest
MacK
by MacK » Fri Jun 29, 2007 5:25 pm
Wondered what you were doing with the nut wrench out
by Rich H » Fri Jun 29, 2007 5:27 pm
You did torque them properly didn't you?
This guy didn't!
by Shug » Fri Jun 29, 2007 5:35 pm
Yes, of course (most of the time...)
YvoTuk
by YvoTuk » Fri Jun 29, 2007 6:35 pm
bertieduff
by bertieduff » Fri Jun 29, 2007 7:13 pm
Brutal!
Lost a rear wheel years ago. It overtook me doing about 50 as I ground to a halt in a shower of sparks. Looked pretty
in a scarey way
"I thought YOU torqed em"
"No, I thought YOU did!"
Don't try this at home.
For educational purposes Shug, how obvious was it?
by Shug » Fri Jun 29, 2007 10:08 pm
Well, looser rear than usual (steady) plus a thumpy sound (similar to a movie 'flat tyre' special effect) that got louder. Presumably as the wheel moved more......
fd
by fd » Fri Jun 29, 2007 10:13 pm
mini metro i think . . . but there is more than one length . . .
Fd
by Victor Meldrew » Fri Jun 29, 2007 10:20 pm
You will need a wheel bearing as well mate.. dont think they can be done without removing the hub... bit of a bummer that one.
- Jedi Master
by robin » Sat Jun 30, 2007 7:19 am
A sharp clout to the flange with a large hammer should see it clear the bearing without the bearing falling apart.
John is right that they won't come out without taking the flange out.
Neil Mckean has a damaged flange with four perfectly good wheel studs in it, if you wanted to make him an offer for them, I am sure they could be removed and SE couriered over to somewhere near you this weekend.
by Rich H » Sat Jun 30, 2007 8:47 am
Fnarr fnarr, he said flange.
Sorry, I'll go back to work
by Shug » Sat Jun 30, 2007 9:24 am
robin wrote:A sharp clout to the flange with a large hammer should see it clear the bearing without the bearing falling apart.
With a rare bit of good fortune for me, that's actually a bearing that's needing done anyway and I already have the spare for the job.
Length is 36mm, according to MMC Parts Guy. Will give McGinge a shout and I'll go snooping around factors on Monday for the rest (want to replace them all sooner rather than later, for peace of mind...)
by Rich H » Sat Jun 30, 2007 9:32 am
That'll learn you for using WMD on wheel nuts
How long ago did you last have them off (As it were!)
