scottyf
by scottyf » Thu Aug 09, 2007 9:52 am
Does anyone know anything about Generators? Can anyone recommend one or lend me one for a couple of days?
I need to be able to run an amp, speakers and an LCD monitor outdoors (albeit in a Marquee).
Is it possible to buy an invertor or summat similar and just run them from a car?
I aint no electrical engineer, so any advice much appreciated.
Ta muchly
Scott
MacK
by MacK » Thu Aug 09, 2007 10:37 am
An amp, speakers and LCD monitor would be far too much for an invertor from a car.
Is it just to rent/borrow you need one? I could sell you one?.........
Can you find out how much load the amp and speakers etc will draw, should be on them....
by GregR » Thu Aug 09, 2007 10:51 am
get an extension cable from a nearby house
RDH
by RDH » Thu Aug 09, 2007 10:52 am
GregR wrote:get an extension cable from a nearby house
Helpful as ever Mr Rolfe!
Daveb
by Daveb » Thu Aug 09, 2007 10:53 am
You can get little generators from Makro for about £50, should run that lot.
by GregR » Thu Aug 09, 2007 10:53 am
one does one's best.
for those that care, I'm still completely oiled
MacK
by MacK » Thu Aug 09, 2007 10:55 am
GregR wrote:one does one's best.
for those that care, I'm still well lubed
scottyf
by scottyf » Thu Aug 09, 2007 11:16 am
LCD monitor:
100-240v
1.6a (50/60hz)
Amp and speakers:
Input 230v - 50hz 164 mA
output 12v 1.5a 18VA
does this help?
I could probably get away with running a laptop instead of an LCD monitor.
would I be able to run a laptop power supply and the amp from a car invertor?
by Sanjøy » Thu Aug 09, 2007 1:16 pm
Aldi were punting a mega cheap one a while back
by Rich H » Thu Aug 09, 2007 2:12 pm
From that:
Screen
250x1.6=400W
Speakers:
250x0.164=~40W
So a genny over 500W will be fine, most little ones will do a couple of kW.
s333fee
by s333fee » Thu Aug 09, 2007 3:34 pm
best to get one a bit bigger.
for example microwaves claim to be 650 w, but only 50% efficient so need 1.2Kw to work.
so bigger is better.
by BiggestNizzy » Thu Aug 09, 2007 4:08 pm
s333fee wrote:best to get one a bit bigger.
No Biggest is better
