Bulkhead Heat shield
haggis catcher
Post by haggis catcher » Thu Aug 30, 2007 5:39 pm
My Heat shield is goosed. :cry: Elise parts dont do them, and they say its a lotus part only. Any other ides where to get one?
Elise S1
Post by campbell » Thu Aug 30, 2007 7:10 pm
Stew,
My understanding is that the heatshielding in this area is so critical, you are best not to skimp. So if it's Lotus only, I'd get on and do it before any damage occurs!
If it's just part of the exhaust manifold shielding, however, I think you can make up your own from that nimbus stuff or whatever it's called.
Fergus has done that I think.
Campbell
haggis catcher
Post by haggis catcher » Thu Aug 30, 2007 10:08 pm
Cheers Campbell. Its not the small one the is attached to the manifold, its the one on the bulkhead almost behind my seat. It looks like a burst pilliow just now. :(
Elise S1
Post by robin » Fri Aug 31, 2007 8:12 am
What vintage is the car?
There are three types of heatshield that fit here.
The really early S1's (e.g. ed&ali's) are fitted with two large sheets of the same type of board-like material as is used to construct the manifold shield.
Not much later S1s (e.g. my old R-reg silver shed) had the rubber&tin foil mat stuck to the bulkhead instead.
Once you reach the down-and-under coolant pipe instead of the up-and-over variant, the bulkhead is a different shape with different mountings for the manifold heatshield; it still uses the foam&tin foil mat but it's a slightly different shape I think. Lotus may supply a single part to "fit" both bulkheads ... not sure.
The mat variant is a pain to peal off and replace - I did mine when the engine happened to be out and it still took a fair amount of time.
The board variant is pretty easy to replace in principle, but I'll bet it's a barsteward when you come to do it.
Actually you don't need the bulkhead insulation either way (it's for driver comfort) but you must have the manifold heatshields otherwise you set fire to the bulkhead itself, eventually.
A couple of sheets of nimbus would work as a heatshield bonded to the bulkhead in place of the either the mat or the board - *but* watch out for resonance and also there will be no sound insulation (the opposite probably - the Nimbus might make it louder).
haggis catcher
Post by haggis catcher » Fri Aug 31, 2007 3:30 pm
Braw stuff Robin. Its one of these board types, that has fell to pieces. I have ordered one form MMC. So i should have it next week.
Thanks again
Elise S1
