Black wheels and undertray? Opinions?
It's "Kwik-Fix" Super Glue. I think I might have some tar remover in the garage. Will try that tomorrow. If that doesn't work, I'll maybe try something from that website. Cheers Rob.
I'll probably end up just putting up with it and hoping that the dirt hides it!
You can get superglue remover, IIRC it's acetone. It might affect the powdercoat but I doubt it. Failing that get an ice cube on it so it's good and cold then see if it will chip off, superglue is strong but brittle.
Stuck the diffuser back on tonight and it looks cool.
Really glad I got it done. Just looks so much better - I can't believe Lotus don't send them out the factory like this.
Managed to get the worst of the superglue drips looking a bit better and you don't really see them too clearly once it's back on the car. Just looks like dirt.
RICHARDHUMBLE wrote:You can get superglue remover, IIRC it's acetone. It might affect the powdercoat but I doubt it. Failing that get an ice cube on it so it's good and cold then see if it will chip off, superglue is strong but brittle.
No need for ice cubes.... just park it outside one evening, or do it next time you are at KH.
Some folk are clearly forgetting that Scotland is not as balmy as Preston
The spare I was left with from the 3m I ordered wouldn't really be enough to be used in place of any cock-ups (which are quite likely knowing me
). I didn't actually measure what they sent me . . . maybe they didn't send 3 metres.
Gorrie, whatever you do, don't use superglue to stick it on if you're a cack-handed oaf like me and liable to drip it! Use something else that won't stain the black powdercoating.
- thinfourth
