Stupid question... and no I am not female ;)
Re: Stupid question... and no I am not female ;)
Post by robin » Wed Jul 13, 2011 3:53 pm
Is this a VVC engine? It appears to have oil cooler take off pipes fitted. If you don't know for sure, take a picture of the engine bay from the top ...
Post by Shug » Wed Jul 13, 2011 4:01 pm
robin wrote:Is this a VVC engine? It appears to have oil cooler take off pipes fitted. If you don't know for sure, take a picture of the engine bay from the top ...
It is mate - he's previously posted some issues WRT VVC ECU replacement.
Post by robin » Wed Jul 13, 2011 4:36 pm
OK, so then I wonder if there might be an issue with the VVC oil cooler pipe work - these do break (although I'm not sure if they break when provoked by ham fisted mechanics or whether they fail in service). A broken VVC oil cooler pipe might lead to some intermittent loss of oil pressure I suppose ... not sure if they are always in circuit or only when oil is too hot/too cold.
CubanGav
Post by CubanGav » Wed Jul 13, 2011 4:50 pm
Rich H wrote:Do not remove the switch It'll pish oil everywhere!
Pull the connector and ground the wire and the light should come on, then wiggle the wiring see if the light flickers.
Edit oops to late...
Post by Rich H » Wed Jul 13, 2011 6:10 pm
I tried to post it and it said another post has been made... :lol:
cla5h
Post by cla5h » Wed Jul 13, 2011 10:42 pm
Can anyone advise what's involved in changing the oil pressure switch - can you just pull it out and get the new one in quickly without losing too much oil, or does it need to be drained? Mine apparently has a small leak from it (and I also get an occasional random flickering of the warning light.)
Izi.., where did you purchase the new one from?
BTW, on your original point, I have the same issues reading my oil level. The XXX's on the stick will have some oil over them, although it usually looks heavier at the bottom of the gauge that the top, so I can never tell if it needs topped up.
Robin, re oil cooler pipes on the VVC - mine corroded quite early in the car's life, I think around a point where they're held by a clamping plate.
Post by Rich H » Wed Jul 13, 2011 10:58 pm
Just change it quick, pop your thumb over the hole and you won't loose much but cardboard is a good idea!
It'll be a rover part so should be easily available fomr your local motor factor.
izibecoz
Post by izibecoz » Thu Jul 14, 2011 8:00 am
Yup autosave 7.99 - cheap as chips. Two day delivery though
Will be firing it in ASAP with the thumb technique above .. Oh and cardboard this time :)
pitstop
Post by pitstop » Sat Jul 16, 2011 1:30 pm
I personally wouldn't drive it until I got to the bottom of the flikering oil-light issue. If the oil light is genuinely indicating low oil pressure, you WILL damage the engine.
Post by Mikie711 » Sat Jul 16, 2011 2:12 pm
IIRC the low oil pressure warning light on the VVC is set at 15psi. There could be a number of reasons for this ranging from a generally worn engine to clogged oil pick up and anything in between. Once you have ruled out the pressure switch and the problem still persists then thing get considerably more complicated. Hopefully, for your sake it will be the switch that's gubbed.
Just realised your in Aberdeen, if you want a hand then PM me your number. Might be a bit late but pretty sure I have a spare pressure switch knocking around.
Mike
izibecoz
Post by izibecoz » Sun Jul 24, 2011 6:27 pm
Ok so after a week away, I finally got round to fitting the new sensor. Quick trip to aberdoom and back and no light "yet".... Will do a few more miles and see how it goes.
However?! I was putting the under tray back on and in my haste to get it finished whilst trying to get the axle stands in place I tripped over the trolley jack... Hey fcuk presto the thing slipped and i now have a round hole on the side of the car ... I am so sick with myself! Anyone know where to get this thing fixed??? In or around aberdoom!!!
Thanks
Izi
CubanGav
Post by CubanGav » Sun Jul 24, 2011 6:32 pm
Castlepark autobody in Ellon. Many on here used them and top workmanship.
Thats bad luck - I'm always paranoid about jacking it up for exactly this reason. Glad the sensor worked though.
Chin up.
izibecoz
Post by izibecoz » Sun Jul 24, 2011 6:35 pm
Actually felt physically sick when I kicked it... The crunch!! Urg!!!
Just yet another thing to piss me off :(
Post by tut » Sun Jul 24, 2011 6:48 pm
Post a pic izi.
izibecoz
Post by izibecoz » Sun Jul 24, 2011 9:22 pm
Will put one on tomorrow guys... Having max wine consumption to ease the pain :(
