Jamie84
by Jamie84 » Fri Aug 22, 2008 6:45 pm
Iv never actually been sure what the legal limit is on tread , just read that its 1.6mm? cambell ?
anyway my rears are not far off the tyre wear indicator , although dont really look anywhere near 1.6mm...so what exactly does the indicator indicate ? are the tyres illegal when the tread is level with indicator ? I would have thought this was the case but as I said doesnt really look 1.6mm...
hoping I can get the rest of the summer?
out of them , then replace with a winter tyre maybe.
by Corranga » Fri Aug 22, 2008 6:51 pm
reckon the law is something like 1.6mm across 3/4 of the tyres breadth and all the way around.
I supposed the depth indicators are exactly that. Maybe the tyre manufacturers try to get you to buy tyres before you need them (legally) or their guides are based on the particular tyre? I'd imagine they aren't necessarily UK law either as I suppose they sell the tyres in different countries too...
Chris
Edin430
by Edin430 » Fri Aug 22, 2008 7:17 pm
I'm just about to stick a full set of Yokohama S and C Drives up for sale for £60...
Basically brand new and retail over £100 per tyre if you want them?
Got a full set of T1-R's to fit.
Lewis
Jamie84
by Jamie84 » Fri Aug 22, 2008 7:58 pm
whats the different between s / c drives ?
£60 for a full set ! ?
Edin430
by Edin430 » Fri Aug 22, 2008 11:12 pm
Yup full set mate... Wont have any room to store them!!
http://www2.yokohama-online.com/gb/tyre ... .php?g=151 details
You cant get the S and C drives as a full set in Lotus sizes, hence the mix! S on back and C on front.
I'm running them at the moment welcome to check them out
Will def see you through until next year.
Lewis
oh btw - S drives are what the new Evora will be running
by mac » Sat Aug 23, 2008 8:29 am
Legal minimum is 1.6mm of tread across 3/4 of the width of the tyre.
wear indicators are generally at 2mm so you have time to change the tyre before being illegal.
Any doubts on the legality of your tyres swing past a kiwk fit or similar and they will measure them for you - and then try and sell you a set at which point you tell them that the compound is dealer supply only but thanks for the check
Jamie84
by Jamie84 » Sat Aug 23, 2008 8:50 am
okay guys thanks for the advice , better to be safe than get 12points? for 4 bald tyres !
i'll defo take them lewis ,would like 048s again but cant justifiy running them through winter ,they'll prob be gubbed by January. When/where you planning to get the toyo swap done m8 ?
Edin430
by Edin430 » Sat Aug 23, 2008 9:33 am
No probs
I'm away to London on Tuesday for a bit but planning on getting Ali to swap them next weekend.
I'll prob leave them at his and then you can get them there? He has a guy that fits them for £15 a corner IIRC.
Maybe be able to sell your 48's as track tyres and get your money back
Sure someone would spend £60 on even 4 bald ones just to blast them round a track!
Lewis
