Tightening handbrake
Anyone know how easy a job it is to tighten up the handbrake? Thought it would've been done at the service but wasn't and it really could do with it.
Cheers.
Cheers.
Re: Tightening handbrake
Undertray off, then two spanners to undo the lock nuts and adjust. So 5 hours or sosimon wrote:Anyone know how easy a job it is to tighten up the handbrake? Thought it would've been done at the service but wasn't and it really could do with it.
Cheers.
Brilliant!robin wrote:Undertray off, then two spanners to undo the lock nuts and adjust. So 5 hours or sosimon wrote:Anyone know how easy a job it is to tighten up the handbrake? Thought it would've been done at the service but wasn't and it really could do with it.
Cheers.
Lawrence, can't you do a Spanners and Sponges every week-end??
scott
Had a look at the service manual and it looks like you need to measure the distance between the caliper and something else (forgotten right now). Then you can just tighten the cable using the lock nuts on the left side of the car and ensure that the measure distance doesn't go below whatever distance it said the the manual. Clear enough?
In summary: it looks like a piece of piss but will probably be like Robin said
Nah. Loctite is designed to be undone with normal tools. In fact I do the opposite for these bolts and fit them with copper grease each time I put the tray back on. The bolts seize in the C-clips really easily and then when you apply sufficient torque, the C-clip sheers leaving you no choice but to use WMD. Don't be scared, just grind the head off the bolt (assuming we're talking the wee M5 (8mm head) bolts, not the 4xM8s (13mm head or on later cars these are 5mm hex drive heads IIRC). You shouldn't have trouble with the M8s - just use a big spanner/socket drive if you have too - the M8 bolt is tough enough.Scottd wrote:Would that be the under tray bolt caused the rattling after you got it back from Murrays that they then maybe used Loctite onThey woudn't be that silly tho would they
scott
If you have rounded off the middle of the hex-drive with a badly fitting key then can flatten off two sides with a file (make them parallel) until you can get a spanner on it. Failing that you're looking at drilling and removing with an Easy-Out type of thing (left handed corkscrew).
