Which Radiator??
Which Radiator??
Just been told by Steve Walker that my radiators leaking. Seeing as the clams off anyway I'm probably best getting a new one installed. Should I just go with the standard Lotus one or one of the upgraded ones from Eliseparts?
Neil
Neil
Exige V6
Re: Which Radiator??
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
I had a proalloy high capacity one fitted a few months back that I bought direct from here - http://www.proalloy.co.uk/cgi-bin/sitew ... d=proalloy
They also make the cheaper eliseparts version but dont sell that direct to the public (or at least didnt when I bought mine).
I bought teh high capacity one on the premise that bigger and more expensive was better
It also looks shiny, but you cant see this when its fitted. If you fit a new Lotus one with the plastic bits it will only fail again maybe a couple of years down the line.
Proalloy it is then. Anything else worth getting done while the clam's off?
Exige V6
Check the cooling fan, not just for function but for sound - if it's starting to sound a bit "rough" on start up then now's the time to replace.
Depending on the age of the car it might be an idea just to swap it out for a new one anyway - the cost of the fan itself is buttons compared to the labour removing and replacing the front clam.
I'm a bit far away from the car to check it myself - its an '04 so maybe due. Would you recommend the standard Lotus one or an "upgraded" Eliseparts one?mac wrote:Check the cooling fan, not just for function but for sound - if it's starting to sound a bit "rough" on start up then now's the time to replace.
Exige V6
I've never had a fan go, but both my elises have done there rads. If it were me i'd get an upgraded rad and leave it at that.
I think I heard...maybe on another thread, search for Fd posts...that actually unless you are doing some other appropriate mods at the same time, sticking with a standard rad is the correct thing to do.
A forum search project for you there, then, Neil
I assume he meant standard SIZED rad, not standard rad. theres no real need for a bigger rad, just one that wont break every couple of years.
mckeann wrote:I've never had a fan go, but both my elises have done there rads. If it were me i'd get an upgraded rad and leave it at that.
Yeah - but on both your cars the fan would get a bit of a work out. It's when it sits doing nothing for the best part of the year that it starts to go. When I had the elise on track most weeks it wasn't a problem, now that it's "retired" it's very noisey and is needing replacing.
2p
Radtec do a nice radiator built to order
http://www.radtec.co.uk/index.php?p0=de ... rtNo=RLEL1
nice company to deal with too
bob
