revs sticking
revs sticking
I seem to only have daft questions to ask on here but I have to ask somewhere!
Just noticed while driving around today in my S2 that whenever i dip the clutch the revs drop to about 1500, stick for a second or two then eventually drop down to a normal tick over.
Any suggestions? Or is this something I've just not noticed before - I don't think even I could have been that unobservant tho...
cheers.
cheers.
Re: revs sticking
Is the car still moving at the time?
Re: revs sticking
IACV possibly. Seem to get a bit clogged up and need taken out cleaned and poped back in. From memory its only like 2 or 4 torx take it out spray brake cleaner then turn your key 2 clicks so electrics are on but car not starting and hold the top so it doesnt pop right off but moves up a bit spray spray good shake out and see if that solves the problem
1999 S1 Elise 111S - Fun Spec
Re: revs sticking
Its that bit there
Re: revs sticking
What car do you have , Toyota or K series ? On the k series cars the idle is higher when on the move , think about 1200 rpm . Don't know if the Toyota engined cars have the same feature at a different rpm.
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
Evora S (sold)
Re: revs sticking
Yotas have the same feature.
Re: revs sticking
I was going to look clever there and you both have spoiled it!
Re: revs sticking
Pic you showed is an S1 - the IACV and plenum on the S2 is totally different mates29ttc wrote:IACV possibly. Seem to get a bit clogged up and need taken out cleaned and poped back in. From memory its only like 2 or 4 torx take it out spray brake cleaner then turn your key 2 clicks so electrics are on but car not starting and hold the top so it doesnt pop right off but moves up a bit spray spray good shake out and see if that solves the problem
Re: revs sticking
...takes some doing....meatball wrote:I was going to look clever there and you both have spoiled it!
Re: revs sticking
Shug wrote:Pic you showed is an S1 - the IACV and plenum on the S2 is totally different mates29ttc wrote:IACV possibly. Seem to get a bit clogged up and need taken out cleaned and poped back in. From memory its only like 2 or 4 torx take it out spray brake cleaner then turn your key 2 clicks so electrics are on but car not starting and hold the top so it doesnt pop right off but moves up a bit spray spray good shake out and see if that solves the problem
Depends on which S2 you have, the location on an early K is the same although the shape is slightly different, but with a clear and concise photo like that you wouldn't go far wrong.
Re: revs sticking
Skim reading
But still may solve the problem
Suppose it does depend what engine he has but sure someone can point him in the right direction of the IACV
Re: revs sticking
Thanks very much for the replies...
It's a toyota engine, '57 plate, S2. It's still under warranty...I'm not the most technically minded (the picture and description were a big help so thanks s29ttc- I might just take it back and see what they say - I just didn't want to be taking it back for no real reason.
Re: revs sticking
Question - is it still moving, then dropping idle as you come to a halt?
If so - don't take it back, they all do that. It's part of the mapping. Nothing to do with an idle valve.
Re: revs sticking
stop it stop it stop it! I WANTED TO LOOK CLEVER....I KNEW THAT ONE!Shug wrote:Question - is it still moving, then dropping idle as you come to a halt?
I'm not playing this game any more!
Re: revs sticking
makes no odds - on stop or coasting same issue..Shug wrote:Question - is it still moving, then dropping idle as you come to a halt?
maybe it's just me picking up on it now - the more i drive the more annoying it is because i know what the engine tone's going to do!
