Hubble Bubble..
Hubble Bubble..
Post by GregR » Thu May 18, 2006 1:58 pm
Was down in the passanger footwell trying to retreive some change last night (tight git that I am) and had the mat up. I noticed quite a few 50p sized raised parts under the rubber floor covering. I was a bit worried, then hauled out the pax footrest and there was nowt there... Could this just be dirt thats got under the rubber cover, or should I get my behind in gear before my anti-corrosion warranty runs out?
Ta
Post by Shug » Thu May 18, 2006 1:59 pm
Do it....
8)
Post by GregR » Thu May 18, 2006 2:14 pm
I'm disappointed in you Shug, not even an attempt to say the raised bits could've been 50p's? :roll:
Post by Shug » Thu May 18, 2006 4:10 pm
Do it....
(the rubber mats are taped down on 4 sides. The only thing getting under them is corrosion - in your case it'll probably be a simple treatment & not new floors)
8)
Post by GregR » Thu May 18, 2006 4:27 pm
will do, cheers Shug.
<thumbs through owner's manual to find what to do next>
Hmm, call to MMC or to Hethel?
P.S. I am capable of wiping my bum myself, just incase anyone was wondering
Post by Shug » Thu May 18, 2006 4:52 pm
MMC (lucky you) :roll:
Post by Rich H » Thu May 18, 2006 4:55 pm
How old is the car? I found my floor corrosion 1 month outside the anti-corrosion warranty....
Pull up the mats ASAP and dry it out, get to MMC there is a free fix depending on the extent of the damage. May be free mats, may be a new bonded in floor. I have a stylish bare metal floor under my carpets.....
The worst cases actually holed the floor but mine was just a bit of blue/white powder and a bit of light pitting.
The PVC mats reacted with the Ali.
HTH
Post by simon » Thu May 18, 2006 5:01 pm
IIRC it wasn't that the PVC reacted it was the stuff they were stuck down with and combined with the PVC being non-breathable, any moisture that got in stayed there making the corrosion worse.
Post by Sanjøy » Fri May 19, 2006 12:49 pm
How long is the warranty ?
Post by Rich H » Fri May 19, 2006 5:28 pm
8 years. :roll:
