Door Mirror
cjm
Door Mirror
Post by cjm » Sun Jan 01, 2012 10:07 pm
Any one know the best way to dismantle the spring part of the door mirror so I can reuse the current coloured part? Someone has snapped it off and the bottom lug is broken.
Colin
10-15 S2 Elise 111S
17-23 S1 Evora
Re: Door Mirror
Post by Ferg » Mon Jan 02, 2012 1:50 pm
If possible when you're doing the mirror, i'd be interested in a pic of the plastic colour bit coming off, I think something isn't quite sitting right on one of mine but can't picture how it looks inside. :-)
Re: Door Mirror
Post by Rich H » Mon Jan 02, 2012 4:10 pm
Are they the same rover 100 mirrors as the S1? If so the case pops apart along the seam so you can access the insides.
Don't think the spring bit comes seperately though, I ream to remember it's a spring washer pressed on that holds it all together.
(My mirror just fell off without provocation!!)
Re: Door Mirror
Post by alicrozier » Mon Jan 02, 2012 10:25 pm
Re: Door Mirror
Post by tut » Mon Jan 02, 2012 11:24 pm
Complete mirror assembly from Dingbros is £10.50.
cjm
Re: Door Mirror
Post by cjm » Tue Jan 03, 2012 2:39 am
Here are some photos of the mirror.
http://gallery.seloc.org/albums/userpic ... lips_2.JPG
http://wiki.seloc.org/a/Door_Mirror,_So ... _Replacing
http://arc.seloc.org/viewthread.php?tid=154346&page=1
Managed to dismantle my mirror and need to get one from a scrappy and swap over the broken part so I don't have to get mine sprayed. Should be fun trying to get the long spring back on!!
I'll take some photos when I'm putting it all back together.
Colin
10-15 S2 Elise 111S
17-23 S1 Evora
Re: Door Mirror
Post by tut » Tue Jan 03, 2012 10:40 am
I had no problem with the spring using a mole grip, better with two of you though.
Mikem7709
Re: Door Mirror
Post by Mikem7709 » Wed Jan 04, 2012 10:39 pm
My passenger side glass seems to be a bit loose, the unit itself is tight but the glass "rattles" when the engine is idling.
How is it held into the frame ?
cjm
Re: Door Mirror
Post by cjm » Sun Jan 08, 2012 6:48 pm
If you look at the first link I posted above you can see there are small clips on both halfs, the coloured back section and the glass/mirror section. The two halfs just push and clip together.
I'll check when I'm back home and see how the mirror is held in its plastic half.
Colin
10-15 S2 Elise 111S
17-23 S1 Evora
cjm
Re: Door Mirror
Post by cjm » Mon Jan 09, 2012 1:10 am
The mirror glass is just clipped in place, you would have to take the mirror apart and try to either glue the mirror to the frame at a couple of points or slip something between the mirror and the frame and clips to take up any slack. Or you could replace that whole frame and glass part of the mirror as it isn't handed or coloured and is on lots of rovers.
Colin
10-15 S2 Elise 111S
17-23 S1 Evora
Mikem7709
Re: Door Mirror
Post by Mikem7709 » Mon Jan 09, 2012 2:08 pm
Cheers Colin, I'll pull it apart and get the glue gun oot.
Re: Door Mirror
Post by Ferg » Fri Jan 13, 2012 2:40 pm
Thanks for the pics, they're really helpful. :)
Mikem7709
Re: Door Mirror
Post by Mikem7709 » Fri Jan 13, 2012 3:15 pm
Mine came off really easily, start at the rubber boot with a blunt plastic implement.
If the mirrors still on the car, the painted part will remain attached and the glass and frame come away.
