Just fitting some new pads on the the Pug and was surprised by the amount of chamfer on the pads
Who knewDavid wrote:The geek in me got the better of me and I found this:
http://www.kyu.edu.tw/teacpage/teacpage ... C98-69.pdf
Seems it's to reduce brake squeal and the loss of stability/efficiency that results. The reduce pad area is of little consequence as Amontons law states that friction force remains the same.
BiggestNizzy wrote:Who knewDavid wrote:The geek in me got the better of me and I found this:
http://ocw.mit.edu/courses/physics/8-01 ... lecture-8/
Was going to moan about spending money on wide tyres but.... 3.10
http://ocw.mit.edu/courses/physics/8-01 ... s/sol3.pdf
That took me back a bit, god I hated being a student!
Who knew
The car doesn't "un-stop" when you take your foot of the brake. The accelerator makes the car "un-stop" or using the technical term go.martins wrote:
FFS. We is not all engineers.
Stamp on the brake pedal, the car stops. Take your foot off the brake pedal the car un-stops....Unless you have a real old and dodgy S1 or a water bottle under the brake pedal. Simples.
Now we are getting somewhere. The above is far easier to understand than the man from MIT (Mind Induced Tedium).The car doesn't "un-stop" when you take your foot of the brake. The accelerator makes the car "un-stop" or using the technical term go.
