________
cla5h
________
Post by cla5h » Tue Feb 25, 2014 5:40 pm
________
Re: Clam off, replace fans?
Post by mckeann » Tue Feb 25, 2014 5:57 pm
If its a standard plastic end cap rad I would stick an all Ali one in there. Not cheap, but you KNOW it will fail next week if you don't.
Post by Dominic » Tue Feb 25, 2014 6:12 pm
Sorry to hear about the bump.. would be a real shame if it had damaged the rad and fans too....
Post by j2 lot » Tue Feb 25, 2014 6:17 pm
:withstupid :wink:
If its not been done you should replace the resistor pack and do the factory mod ( drill holes so water drains).
AJT
Post by AJT » Tue Feb 25, 2014 6:38 pm
Look at replacing or painting the towing post.
Alan
S2 111S
cla5h
________
Post by cla5h » Tue Feb 25, 2014 7:19 pm
________
Post by robin » Tue Feb 25, 2014 9:50 pm
I have never had the fan fail, though they do seize. I guess the question is how often do your fan(s) run normally? If they normally run as part of your usage of the car then I would guess they won't seize and aren't likely to fail.
Post by campbell » Wed Feb 26, 2014 12:50 am
Ali radiator definitely. Don't buy the mega expensive hi-flow, just look for cheapest all ali model. Check rad hoses & clips. Certainly get fans checked out but don't change unnecessarily. Driving lamp brackets?
Post by Sanjøy » Wed Feb 26, 2014 8:58 am
Fan, rad, headlight brackets, tow post & air horns.
cla5h
________
Post by cla5h » Wed Feb 26, 2014 9:41 am
________
Post by Shug » Wed Feb 26, 2014 10:12 am
Elaine's fans have packed up in the past. They weren't insane money when she had them done, so might be logical preventative maintenance as part of a bigger bill if you can stomach it? If it's going into MMC, I'm sure they'd be able to give them a spin and a listen for you, to advise if it's sensible.
cjm
Post by cjm » Mon Mar 03, 2014 2:59 pm
Mine seized a couple of years ago, I think mainly due to them very rarely kicking in and the car having sat over winter while I had a company car. I didn't notice until in a queue at a toll on the way back from Le Mans when the temp incresed and then blew the plastic end cap off the rad. All the brackets and fixings were replaced at the same time.
Colin
10-15 S2 Elise 111S
17-23 S1 Evora
cla5h
________
Post by cla5h » Mon Mar 03, 2014 7:14 pm
________
Post by Shug » Tue Mar 04, 2014 9:40 am
It's more a listen - they should be able to hear and feel by hand if the bearings are past their best.
Post by Sanjøy » Tue Mar 04, 2014 11:44 pm
Is that not a self tesi test?
