Horn push wiring
Re: Horn push wiring
Post by Gareth » Mon Sep 15, 2008 11:05 am
tut wrote:That is truly ugly.
Just wait till you find out which SE'r bought it!!! :D
P.S
I could do with the hub puller too.... :thumbsup
Post by alicrozier » Mon Sep 15, 2008 11:58 am
Kev wrote:Ali,
I've got a 2/3 leg puller which should work if you still need one.
Thanks Kev, I'll give you a shout when I'm back (and have the car back) next week.
Maybe also do Gareths - mini spanners?
Kev
Post by Kev » Mon Sep 15, 2008 1:02 pm
alicrozier wrote:
Kev wrote:Ali,
No worries :thumbsup
I fly out to Florida on the Friday next week, so if it comes to it, I can always organise to drop it off with Gareth.
S2 Elise ST (V6 spec)
Audi A4 Tdi (Shed Spec)
Discovery 3 (Wifes Spec)
Post by alicrozier » Sun Oct 05, 2008 8:40 pm
robin wrote:Are you sure that the mechanism requires two wires? It may be that the switch in the steering wheel connects the one wire to earth to activate the horn; that would then assume there was an earth available, perhaps from the way in which the steering column is connected to the car? I would try running a known good earth to touch the wire that you've found and see if it beeps the horn (unless it's obvious that there should be a second wire, e.g. witnessed by the presence of a second spade terminal with nothing connected to it ...).
I got a proper look at this today, horn push worked fine when 2nd spade terminal grounded. There was also a spring clip thingy which looked like it was supossed to provide a ground to the wheel mount (when this was grounded properly it worked). Anyway, 'adjusted' the clip and all good. :oops: :D
Additionally I hardwired a 3-way 12V socket (switched power from the stereo). It's mounted below the dash for phone and satnav charging and adds a 'fast & furious' blue neon lighting to the footwells. :D
When I had the stereo out discovered why the radio reception had been poor...reconnected the aerial. :thumbsup
Post by robin » Tue Oct 07, 2008 12:04 am
Excellent job on the blue LED. Now you need Nox cylinders and a dodgy laptop bolted to the footwell and then an infinite selection of downshifts and you'll be a real street racer ...
Beep beep.
Post by Scotty C » Thu Oct 09, 2008 4:52 pm
alicrozier wrote:Yeah took them off.
Of course minus that 50kg of extra front end downforce I understeered off into the first hedge... :roll:
http://www.pistonheads.co.uk/sales/719470.htm
Post by alicrozier » Thu Oct 09, 2008 4:54 pm
:thumbsup will see if he wants them. :D
Fook me they were £110 new... :shock:
http://www.carbonmods.co.uk/Products/Ca ... C4001.aspx
