Pads rattling?
Re: Pads rattling?
Post by meatball » Tue Aug 25, 2009 12:22 pm
Are the pads held in place by pins?
gdr
Re: Pads rattling?
Post by gdr » Tue Aug 25, 2009 2:13 pm
Wheel nuts still tight? I have had that problem before :oops:
Aging biker
Re: Pads rattling?
Post by meatball » Tue Aug 25, 2009 7:43 pm
Paul.A wrote:Yeah
Do the pins rattle?
steve_weegie
Re: Pads rattling?
Post by steve_weegie » Wed Aug 26, 2009 12:45 pm
Paul, i recently saw a similar problem where the pad was moving about in the caliper and making a clunking noise, caused by a small high spot on the disk. If the noise goes away with the application of the brakes, i'd suspect the same.
I'd try fitting anti-rattle pads to the contact points between the pad and caliper. :thumbsup
Re: Pads rattling?
Post by j2 lot » Wed Aug 26, 2009 1:14 pm
steve_weegie wrote:Paul, i recently saw a similar problem where the pad was moving about in the caliper and making a clunking noise, caused by a small high spot on the disk.
... and I never thanked you for your assistance in sorting it. :thumbsup
I have also sorted the 'chirp' that was annoying me and was present on all of the Elises I have owned too, a small piece of rubber hose wrapped around the handbrake cable at each side where it passes through the metal 'hanger' which holds it in place -easy fix and all rattles sorted :thumbsup although it is a Lotus so I'm sure another one will be along soon :wink:
Neil72
Re: Pads rattling?
Post by Neil72 » Wed Aug 26, 2009 6:57 pm
An Aston owner doing DIY spannering ? :damnfunny
Can't you get the butler to take a look at it ?
Edin430
Re: Pads rattling?
Post by Edin430 » Wed Aug 26, 2009 11:22 pm
I seem to be the only one that noticed you mentioned it's when you brake - therefore I doubt it would be the pads ratteling as that usually goes away when your brake!
Are you sure it's nothing to do with anything behind the caliper hitting off the wishbone etc and not the caliper itself? i.e. stainless brake lines. They would move and possibly hit something when you brake - maybe tie them back loosly.
