broken down
Re: broken down
Post by Rich H » Wed Nov 10, 2010 11:25 pm
:lol: Genius :damnfunny
Treat the fuel gauge as a guide... use the trip meter to give you reassurance!
Re: broken down
Post by Shug » Thu Nov 11, 2010 10:10 am
:thumbsup glad to hear it was something cheap and simple.
Re: broken down
Post by campbell » Mon Nov 15, 2010 5:40 pm
LOL, well done John.
Not sure if there is a "fix" to get the gauge a bit more useable...mine goes to Refill after showing 11L and from experience at that point there is usually maybe 5L (rather than 10!) truly left. Has done since new. Good enough for me really.
An elec techie will hopefully be along in a mo to explain!
Re: broken down
Post by Rich H » Mon Nov 15, 2010 6:08 pm
It's a crap design for a level sender, tank is what? 5' long and relatively thin so a float at one end is always going to be dubious at best.
Can't be as poor as the esprit, 2 square ish tanks linked by a 1" pipe and a thin vent line, sender in one tank...
It can go from full to empty in a corner and back again and it is next to impossible to fill it as it takes so long to perculate form one tank to the other.
Does have 2 fillers, but one chap was told off at a shell station for getting his wife to fill one side while he filled the other....! :lol:
Re: broken down
Post by tut » Mon Nov 15, 2010 8:34 pm
Never known one to be that far out, but they are certainly not linear. Mine takes ages to drop from full, goes slowly down to 20, then drops like a stone. As Campbell says, it is not then safe to go beyond 30 miles. N1 however will go for double that when it hits refill.
Re: broken down
Post by campbell » Mon Nov 15, 2010 10:27 pm
tut wrote:Never known one to be that far out, but they are certainly not linear. Mine takes ages to drop from full, goes slowly down to 20, then drops like a stone. As Campbell says, it is not then safe to go beyond 30 miles. N1 however will go for double that when it hits refill.
I just wish our bladders had that kind of capacity, eh friend :mrgreen:
Re: broken down
Post by robin » Mon Nov 15, 2010 11:19 pm
Fuel pump might be on the way out; the in tank reservoir needs to be filled for the pump to work. It might only be working on gravity feed, which at 16L in the tank might not be enough to get up fuel pressure. Or the float is bust. Or you were parked at an extreme angle (like some of the streets in Edinburgh which have really steep cambers at the edges).
Re: broken down
Post by tut » Mon Nov 15, 2010 11:41 pm
Yep, catching Scotty up quickly. However on the Spa road trips, it coincided with re-fuelling, though a couple were leg crossing time which can make throttle, brake, clutch control interesting.
Re: broken down
Post by campbell » Tue Nov 16, 2010 12:22 am
I'm starting to consider retaining the plastic water bottles which I empty down my throat increasingly quickly these days, to empty the processed materials back into in-flight an hour or so later :damnfunny
Re: broken down
Post by Dominic » Tue Nov 16, 2010 10:45 am
Re: broken down
Post by campbell » Tue Nov 16, 2010 11:19 am
Ok I changed my mind!
Right, back on topic everyone please :-)
Re: broken down
Post by tut » Tue Nov 16, 2010 2:42 pm
Good idea Campbell, a litre bottle with a large bore tube and wide funnel would be just the trick.
