FFX - Frolic 2010
Strictly for tarmac whores
ClarkyBoy
Re: Frolic 2010 - the june version
Post by ClarkyBoy » Wed Aug 26, 2009 2:18 pm
brilliant! :thumbsup
Vanlife Sprinter
E30 318is / axle stand spec
987.2 Cayman S
[#]=///=[#] ‘88 Panda 4x4
BSA B31
MF35
Stiga Tornado
Many Bicycles
Post by Andy G » Wed Aug 26, 2009 2:45 pm
tut wrote:Get a few trackdays in at KH Clark, then hopefully Oulton/Cadwell, you have already been out with me and an Instructor, do the same with Robin and perhaps McApe, and Paul will take that on board.
I'd keep quiet about having been out with Tut :wink:
Just teasing - Clarky sure there wont be an issue mate - especially as you'll no doubt be doing some LOT stuff between now and then :thumbsup
ClarkyBoy
Post by ClarkyBoy » Wed Aug 26, 2009 3:32 pm
:damnfunny :damnfunny
[quote="Andy G"Just teasing - Clarky sure there wont be an issue mate - especially as you'll no doubt be doing some LOT stuff between now and then :thumbsup
cheers Andy, sounds good!!
Vanlife Sprinter
987.2 Cayman S
BSA B31
MF35
Stiga Tornado
Many Bicycles
Gourlay83
Post by Gourlay83 » Wed Aug 26, 2009 7:54 pm
This is a must for me, finally enjoy the S1.
Jen is back at work for both dates and thinks that i am going to go with her on a seperate trip. Havn't had the balls to tell her it aint happening and i am off on my own. So will let her read it on here :D , right, im off to the pub.
Alan
P.S Robin, S1 wheel bearings can't be that bad ...................Can they :( ?. Some trip when you pack more wheel bearings than underware.
jen
Girl racer
Post by jen » Wed Aug 26, 2009 7:59 pm
:shock: :shock:
You'll have to divorce me before you get away there without me!!
Schools aren't on hol until the week after the June one, hopefully the August one will be fine....
By the way Alan-it's 'Underwear' :wink:
Post by tut » Wed Aug 26, 2009 8:41 pm
Don't you just love them?
Wonder who will do what, and when, to whom?
Post by robin » Wed Aug 26, 2009 9:17 pm
What's underwear? Can you get it with Ferrari logos?
S1 wheel bearings are fine until you get them and the uprights hot, then put them under a lot of sideways load; then it seems that the various cheesium components expand/bend/otherwise give up enough to allow the flange to wear on the inboard end. This then allows the flange to move inside the bearing and I suppose the bearing is being loaded all on the outboard end. Anyway, soon enough the bearing itself is also shagged. The uprights survive, but pushing bearings in and out of them while cold (which is the way most people do it) must plane off the odd thou of "metal", so once you've changed a couple then the new ones last less time. You're fine if you're still on your second or third bearing I think, but some of the racers were doing a couple of bearings every other weekend ...
So it's really heat that kills them to start with, then wear and tear on the upright and flange reduce the life expectancy of each successive bearing.
For a Honda it's a no brainer that you want the steel rear uprights and if the flanges are tapered, the harder steel flanges that elise parts sell (but don't swap flanges for the sake of it - they're not that cheap!). There's a lot more heat floating around due to proximity of manifold to drive shafts, the brakes and tyres are working harder (more power = more kinetic energy to dissipate) and there's more weight to lug around the corners.
If there was a way to fit the steel rear uprights to the front, I would suggest doing that too - only the truly committed racing driver will notice the increase in unsprung weight ...
Post by tut » Wed Aug 26, 2009 10:11 pm
Bloody minefield Robin, and difficult to know where to stop.
Since I bought N3 2.5 years ago, the only real problem that I have had was with CV joints, and a leaking rad. Took me through FF7 and DP without a murmer, and a lot of trackdays and road run miles since, all on R tyres and not hanging around. On the other hand it could have broken down every other day without too much surprise.
Its no big deal if it breaks down in the UK, but if I make FF next year then that would be the last one, so would do everything that I could to get the car through the two weeks.
Post by campbell » Wed Aug 26, 2009 10:40 pm
robin wrote:Paul, provided you've done either Oulton or Cadwell with LOT and haven't crashed (or at least, they don't remember you crashing/being black flagged) you will be OK - pretty sure you've done at least one Cadwell (hung over, possible minor offage, but it was wet ;-)), so you should be OK. It's just no-novices, not no-FF-novices I think.
Donnie doesn't count then? Pity.
Post by robin » Wed Aug 26, 2009 11:25 pm
Looking at the shop, the next Donnie day _is_ a no-novices day, so I would expect Donnie would make you a non-novice too.
Post by campbell » Thu Aug 27, 2009 9:15 am
I meant our outing at Donnie in April. No funds for any forthcoming TD action, particularly if I am to have any chance of saving up for FF June 2010.
Not to worry, another time :-)
Gourlay83
Post by Gourlay83 » Thu Aug 27, 2009 11:28 am
robin wrote:What's underwear? Can you get it with Ferrari logos?
Makes sense and know its a week point, hence why lotus replaced them with steel ones.
Although I have the Alloy ones on mine (Gulp). Replaced the bearings and measured the hub etc and its all fine but will do a good few track days here and see how they last. Although mine is a honda my manifold is a good 3 inches away from the gearbox/intermediate shaft, so shouldn't have the same trouble with melting cv gators etc but will have all the heat from the extra BHP to worry about.
Ali/Nicola - If your reading this, Think its a great idea to arrive the week before for a nice relaxing holiday before all the madness of 5 track days. Im sure a few others would join us.
Alan
Post by alicrozier » Thu Aug 27, 2009 12:41 pm
Gourlay83 wrote: Ali/Nicola - If your reading this, Think its a great idea to arrive the week before for a nice relaxing holiday before all the madness of 5 track days. Im sure a few others would join us.
Alan
...or have the week after in a nice, air-conditioned, rental hatchback...
(after you're wheels have all fallen off) ;)
Post by tut » Thu Aug 27, 2009 1:41 pm
My drive shaft is about 5mm from the exhaust manifold, can not even get the Honda heatshield between them, so have wrapped the driveshaft in aluminium tape.
May look at getting the latest S/C exhaust manifold as used on the Link-up kit, as mine is the original one designed by Scuffers over six years ago.
Post by Rag_It » Thu Aug 27, 2009 2:15 pm
ed wrote:
robin wrote:You know it makes sense; start saving now ... don't buy any birthday or christmas presents, scrounge more drinks, steal pizzas off drunk people, only order starters when in restaurants, then eat what others don't want (don't just limit this to your own table - if you see the waiter with a tasty half-eaten dish, 'av it). You'll easily save enough money to pay for the trip this way. :-) :mrgreen:
:damnfunny Think ive got most of the above covered already. :oops: :roll: :lol:
You beat me to it!!!
I am gutted it is in June, as getting married on June 5th! Had planned to buy a Lotus in July, and August would have been perfect for FF9!
:( Ah well!
