S1 Audi Elise
Re: S1 Audi Elise
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
Re: S1 Audi Elise
I’ve used aquablast Paisley in the past for a bike frame, seems to be the least destructive means of stripping back to metal.woody wrote: ↑Sat Jan 29, 2022 10:56 amI didn't, think Stephen Curle knows the costs though, it's not huge. I'd spoken to a place in Paisley who would blast the front wishbones for £50.
Hadn't considered galvanising thought, will have a look at it. Plans were also an epoxy paint system on top of that, had a look at Jota marine paints.
I use Jota on stuff offshore, would be ideal in this scenario. On mild steel I’ve used a cold galvanise spray as a primer which provides a cathodic protection then epoxy over. Lasts years in permanently salty wet conditions.
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
Re: S1 Audi Elise
Getting the rear lower o/s wishbone off not going to plan, the last bolt is blocked by the oil sump. So it’s sump off to remove…
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
Re: S1 Audi Elise
When I said it looked like it had lived at the bottom of the sea I wasn’t kidding
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
stratosboy
Re: S1 Audi Elise
they'll still come up looking nice, are you getting them chemically stripped and zinc passivate plated? - I did this with mine and then two coats of clear PIR15. There's lots of theories about what is the best protective coating, but powder coating on wishbones isn't considered a good one as the water gets into the chips caused by stones and causes the coating to flake off.
Re: S1 Audi Elise
Thinking this is the way to go, found a couple places nearby that does it so going to call them today to get a quote to zinc passivate once I’ve had them blasted.
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
Re: S1 Audi Elise
Bits all blasted, left the wheel bearings in to protect the inners, all being replaced anyway.
Got a price to zinc coat at £50 per wishbone plus the other bits so that’s not happening.
Also Nitron came back with £1250 to refurb, mainly due to the springs being knackered but the rest is okay. Just going to buy a new set, makes more sense.
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
Re: S1 Audi Elise
£50 a wishbone is... Quite a lot. Elise parts have new wishbones at £125 each.
Are you coating the hub carrier extrusions?
Re: S1 Audi Elise
Stephen Curle was quoted £100 to do a full car set of wishbones.
Re: S1 Audi Elise
That’s what I was expecting, maybe up to £175 with all the smaller bits.
Got the impression he didn’t want the work, first thing he said was why don’t you get them powder coated
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
Re: S1 Audi Elise
Elise has been put on hold for the last few months due to garage build so I can get it out of the tent
Hopefully have power and slates on soon so I can get the suspension back together and have some proper space to work on it next trip home
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
stratosboy
Re: S1 Audi Elise
wow, new garage space looks fantastic Phil, great work. Got your little helper again too!
Re: S1 Audi Elise
Thanks David, yes he’s always by my side to help out with anything car or DIY related
I’ll need to rebuild the suspension etc to be able to move the car into the garage once the roof is on then will have some proper space to get cracking.
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
