I noticed a hugh difference when i fitted my 4-2-1, I have also gone deaf
- BiggestNizzy
Re: Winter Strip Down and Rebuild (Almost Finished)
Quick update as it's now the end of the cars first (short) season. It has done three events this year two of which have been double entries. Those both being at Boyndie. First was with Victor and the second with Ricky Gauld, guy that built the engine in the end. At the first Boyndie the car took a second in class on the Saturday and a first in class on the Sunday, both in the hands of Vic. Top job by him on both days and showed what the car was capable of given that we spent the whole weekend chasing suspension set up trying to cure some pretty horrendous understeer. and it was only 1/2sec off the class record. At the second event I managed to get PB's on both days and got down into the 70's which was my target.
As for the car, it's definitely quick from the data logger off the line it's hitting 60 in 4.6sec with a top speed down the straight at Boyndie of 79mph in 7.2secs, needs 3rd gear. Still second gear round the in-field and 3rd only on the straight.
Times should tumble once I learn to drive the thing I've built and will be using Mr Walsh's service during the closed season.
I still have the idle problem with the car but that's for another thread and have had gearbox issues which, touch wood, are now sorted. Which leads to it's final spec
Engine:
Sabre Heads Ported VVC head machined follower and lobe pockets. Rog spec inlet valves. Calisbo valve guides.
Piper 1444 cams
Solid followers (shims by KwikRog)
Piper VVC blanking kit
Piper verniers
MLS head gasket
Jenvey 42mm DTH throttle bodies
Jenvey throttle linkage
40mm trumpets
single piece fuel rail
Pico 330cc/min injectors
Omega forged pistons
AE rings
Arrow steel rods
TF160 main and big end bearings
LR uprated oil rail
Original Crankshaft (Used)
New Rover block.
Plans Motorsport welded in sump baffle
Lotus head bolts.
Original Crank pulley
New Oil pump
200ltr water pump
PTP oil filter housing
Gates Timing belt (short)
Manual tensioner.
Lotus Motorsport oil cooler
Mocal oil thermostat
PTP PRRT
Light weight flywheel
ARP flywheel bolts.
EP 4-2-1 exhaust manifold
200 cell cat
EP 6" silencer
SARD adjustable fuel pressure regulator
Goodridge fuel lines and fittings
Walbro 255 fuel pump
Bernard Scouse Airbox
Pipecross Air Filter
Gearbox
Quaife 5 speed straight cut ultra close ratio kit
Steel caged bearings
Quaife ATB
Quaife straight cut final drive kit (4.2)
AP 250bhp clutch kit
Engine management
Emerald K3 ECU
PLX wideband lambda sensor and controller
PLX oil pressure monitor
PLX oil temperature monitor
PLX logger
Xoombox data logger with TC/LC and GPS
Chassis, Brakes and wheels
EP ali belled discs all round with Padgid RS42's
Goodridge Braided hoses
Power Flex Polyurethane bushes
Nitron 2-way adjustable dampeners with eibach springs 325lb front, 400lb rears
Corbeau LE-Pro seats
Scroth harnesses
EP Harness car
Rota slipstream alloys
Thanks goes to so many people for there help and advice throughout the build. In particular Robin and Hiscot on here for steering me in the right direction more times than I care to remember.
So, would I do it again and what would I do different. Well I would go scholar 1.9 and also go the vibration free route with tungsten insertion for the crank. That would have added 3k to the bill which I couldn't afford at the time but it'll be the bases for the sequel. I also would not have used a new crank in an old block. But hindsight is always 20/20.
Thanks for reading and hope that should you embark on your own project this doesn't put you off and maybe provides some useful pointers.
Mike
The End
Engine:
Piper 1444 cams
Piper verniers
MLS head gasket
40mm trumpets
AE rings
Arrow steel rods
LR uprated oil rail
New Rover block.
Lotus head bolts.
New Oil pump
200ltr water pump
Manual tensioner.
PTP PRRT
ARP flywheel bolts.
200 cell cat
EP 6" silencer
Gearbox
Quaife ATB
Engine management
Emerald K3 ECU
PLX logger
Scroth harnesses
EP Harness car
Mike
The End
Re: Winter Strip Down and Rebuild (Done and Dusted)
<Hannibal>I love it when a plan comes together!</Hannibal>
Glad to see it's finally working the way it should. My advice now is leave it alone and drive it until it breaks ... though a vibration-free crankshaft would give you insane RPM ... hmmmm.
good luck mike , i wanted to sprint mine this year but fate has put a hold on that , i also have a close box and was going to get a set of larger exige wheels for the odd track that may require holding onto a gear rather than changing up for a few seconds before a corner ( may give a slight advantage ? )
if you ever do golspie let me know it would be nice to meet up
bob
bob
bob
Hey Mikie, sorry to resurrect this thread from the dead (although it deserves to remain in the SE consciousness for all its worthy information.
But your fuel pump, is this a direct replacement for the OEM unit?
Cornish / Kiwi refugee
Exige S1 in Titanium.
No, it required a bit of modification to the pumps loom. The plugs for the pumps were different, however I have since gone back to a standard pump all be it a brand new one as the walbro is only a single stage pump and gave some fuel surge problems. So unless your going to shell out for pro alloys baffled tank or similar the stick with the original pump.
