removing front discs
Post by r055 » Wed Jun 04, 2008 1:10 pm
anyone got super tips on how to remove a front discs that is seized on?
I've tried tapping the centre of the disc from behind, but still not wanting to move and i dont want to risk damaging the hub assembly/ bearings etc by sledgehammering it!
not really wanting to use WD40 either as i want to be able to stop at some point when out on a run/ track! :lol:
tenkfeet
Re: removing front discs
Post by tenkfeet » Wed Jun 04, 2008 1:17 pm
I assume the locating screw is out :? I drilled the head of one and it did catch.
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
Post by Shug » Wed Jun 04, 2008 1:21 pm
S1 - there's no screw.
You just have to give it some rough love sometimes - mine always seem to fall off. That said, I tend to use a light smear of copaslip when they go back on.
Post by r055 » Wed Jun 04, 2008 1:22 pm
Shug wrote:S1 - there's no screw.
this is the 1st time ive had them off, so cant be sure the last guy who done it used copaslip.
found a post with someone using boiling water - i'll try that next!
Post by Shug » Wed Jun 04, 2008 1:25 pm
Water - pffff
Bloody big 'Poadger' - brute force and ignorance.
Still, try your nancy water method if you must... :lol:
Post by BiggestNizzy » Wed Jun 04, 2008 1:28 pm
Have you removed the calliper ? sounds stupid but recent stories regarding people working on their brakes I have to ask.
Big dead blow hammer, kick it etc. (but not off jack/axel stands)
Post by tut » Wed Jun 04, 2008 1:33 pm
Has anybody tried direct heat, ie blowtorch?
Post by Shug » Wed Jun 04, 2008 1:37 pm
tut wrote:Has anybody tried direct heat, ie blowtorch?
Do you not give your poor bearings a hard enough time without spit-roasting them? :mrgreen:
tenkfeet
Post by tenkfeet » Wed Jun 04, 2008 2:00 pm
Thats a good idea as its a waste of time on the S2 .
No lotus
Evora S (sold)
Post by Shug » Wed Jun 04, 2008 2:08 pm
S1 has old skool studs (off a metro) to locate the disc, as opposed to the chocolate fecking splined bolts the S2 uses.
Post by tut » Wed Jun 04, 2008 2:10 pm
ah so, wondered where the bearings were.
Obviously it would not do the bearing grease much good.
philthy
Post by philthy » Wed Jun 04, 2008 2:11 pm
Best thing would be hammer the disc at the outside edges ie: 3 o'clock then 9 o'clock, 12 then 6 etc etc, hit it pertty hard and it will come off.
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
Post by woody » Wed Jun 04, 2008 5:00 pm
Dry ice on the hub :thumbsup
MacK
Post by MacK » Wed Jun 04, 2008 5:44 pm
:idea:
Get Dominic round with his grinder.
:mrgreen:
Post by Shug » Wed Jun 04, 2008 6:08 pm
Or as Obi used to say "Hit it, don't tickle it" :mrgreen:
