router password help NLC
Jamie84
Post by Jamie84 » Mon Oct 06, 2008 6:58 pm
anyone any idea why I cant log into my routers setting page ? Always been allowed in with "admin - admin" but not today :?
Need to set up some ports for P2P ,So I can download some sister sledge and I cant access it :(
LinksSYS
steve_weegie
Re: router password help NLC
Post by steve_weegie » Mon Oct 06, 2008 7:06 pm
Yup, somebody logged in and changed your default password for you :damnfunny
If you're really locked out after rebooting it, factory reset is the only option.... Just remember to change the default password ASAP
Jamie84
Post by Jamie84 » Mon Oct 06, 2008 8:09 pm
pain in the ass , pressing the reset button , admin works. I get in, reset a new password then I get locked out again :?
Post by Sanjøy » Mon Oct 06, 2008 8:12 pm
Did you buy it off ebay ? Somone might have tried to install ddwrt (I have recently) and it can change the bootloader which knckers things up when it comes to resets of pwds.
Jamie84
Post by Jamie84 » Mon Oct 06, 2008 8:14 pm
well I am in at the moment , will try and get ports forwarded in the meantime .
Nope not off ebay !
Paolo
Post by Paolo » Mon Oct 06, 2008 8:20 pm
I've been using your connection for weeks Jamie. Can't believe the range on that thing!! :damnfunny
Jamie84
Post by Jamie84 » Mon Oct 06, 2008 8:26 pm
:mrgreen:
forwarding these posts is frying my nut .
I Use emule , and my IP changes all the time ie: 192.168.1.101 so i need to change the ports I have forwarded each time ??
Does this sound correct ?
steve_weegie
Post by steve_weegie » Mon Oct 06, 2008 8:31 pm
Jamie,
If you're using port forwarding, you need to do one of these things:
1. Use a static IP address on your computer, not DHCP. Do this if you've got a desktop pc, or a laptop and dont use any other networks.
2. Setup the DHCP service on the router to always assign your computer with the same IP address. Do this is you've got a laptop and you use other networks. You'll need to feed your router the MAC address of your computers network card. You can get this from running IPCONFIG from a cmd window.
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Marvell Yukon 88E8001/8003/8010 PCI Gigab
it Ethernet Controller
Physical Address. . . . . . . . . : 00-1A-F7-3B-1A-22
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 10.1.0.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.1.0.5
DNS Servers . . . . . . . . . . . : 10.1.0.5
NetBIOS over Tcpip. . . . . . . . : Enabled
Feed the router the physical address bit :thumbsup
antonywelsh
Post by antonywelsh » Mon Oct 06, 2008 8:33 pm
Jamie84 wrote::mrgreen:
no idea what emule is but...
Is that the IP address of your PC that you are looking to forward stuff to? if so, can you not setup the router with a static IP address for each device that connects - there should be a list of connected MAC addresses at any given time, you can cross reference the list, get the MAC addy of the PC and give it the same IP all the time, e.g. 192.168.0.101. Thats what i have with everything on my LAN (xbox's, laptops, PCs etc). works a treat for port forwarding.
1999 Bronze MX-5 stuck with for the foreseeable future spec :(
2006 3-dr Megane boot space spec
antonywelsh
Post by antonywelsh » Mon Oct 06, 2008 8:34 pm
or just what he said :withstupid :oops:
Jamie84
Post by Jamie84 » Mon Oct 06, 2008 9:16 pm
well I was kinda lost there to be honest , I have got it working now anyway using upnp .
Will look into it further when messes with the Ip again .
All a bit too confusing for me to be honest !
Thanks guys .
Post by campbell » Mon Oct 06, 2008 9:19 pm
if your password is still the default you really do want to get that sorted, a factory reset (having first output a config backup etc, if you can) is the way forward!
steve_weegie
Post by steve_weegie » Mon Oct 06, 2008 9:34 pm
uPnP.... Factory Passwords.... Do you have wireless? Where do you live? :damnfunny
Jamie84
Post by Jamie84 » Mon Oct 06, 2008 10:14 pm
