Audi TT service
Audi TT service
Post by tut » Fri May 21, 2010 6:31 pm
Ian put it in on Tuesday, running at £2400 at present if they do not find anything else wrong.
S111Y TT
Re: Audi TT service
Post by S111Y TT » Fri May 21, 2010 6:49 pm
£2684.54 I think it is at, maybe ever so slightly less.
Ian Duncan
eoinmac
Re: Audi TT service
Post by eoinmac » Fri May 21, 2010 6:52 pm
:shock: :shock: :shock:
neil
Re: Audi TT service
Post by neil » Fri May 21, 2010 6:53 pm
I can beat that
Exige V6
Re: Audi TT service
Post by renmure » Fri May 21, 2010 7:03 pm
Yikes!! :shock:
I had the 360 and 911 serviced on monday.
Major Service plus quickshifter fitted for the 911 and Major Service plus belts for the 360
Combined total was (just) less than your TT service and I thought I was being spanked
jen
Girl racer
Re: Audi TT service
Post by jen » Fri May 21, 2010 7:20 pm
Jeezo!! :shock:
If it cost me that to service my car, that would be it written off!! :damnfunny
Next time your services are due, let me know and I'l pimp Alan out for half that! :wink: :damnfunny
Jen
Re: Audi TT service
Post by tut » Fri May 21, 2010 7:28 pm
I thought that Jen, could have fed him roasts for a week with a big cheque at the end.
Re: Audi TT service
Post by tut » Fri May 21, 2010 7:33 pm
The garage was recommended to us as opposed to the main Audi agent.
Not actually a rip off there was a hell of a lot to do. Ian could probably post a list. However four hours labour to replace two front wheel bearings sounds excessive.
offshorematt
Re: Audi TT service
Post by offshorematt » Fri May 21, 2010 8:26 pm
Just got my TT out the garage after putting it in for a new power steering rack following a pretty catastrophic failure. Car was off the road for over four weeks while they tried to source me a rack. Audi had a twelve week back order :shock: Sourced three second hand ones - all turned out to be beyond economic refurb, sent mine downsouth to be refurbed to be told it was too far gone, and ended up managing to buy one from an Audi dealer in Bradford (which broke lots of rules apparently as it seems that the audi service network aren't allowed to share stock across the dealers. Despite having them on back order. :roll: )
So I ended up paying £750 for a new rack plus five hours fitting. And I still had to send my fuct one back to them or there was another £100 surcharge :cry:
Turns out while it was in that two of my wheels hd gone square due to the potholes on my commute and both tyres were damaged. So a new set of wheels too and a new pair of tyres (following a new pair less than six months ago when I tore both within three days on particularly nasty potholes...)
The minor service I had done at the same time was pennies in comparison...
German car prices, eh? As Renmure says, it makes the Italian equivalents look honest :lol:
Re: Audi TT service
Post by tut » Fri May 21, 2010 8:37 pm
Join the club Matt, finally get raped after 70 years of virginity.
S111Y TT
Re: Audi TT service
Post by S111Y TT » Fri May 21, 2010 11:38 pm
BREAKDOWN OF PARTS AND LABOUR ON AUDI TT
LABOUR CHARGES PRICE QTY VALUE
TO CARRY OUT SERVICE 2
TO CARRY OUT BRAKE FLUID SERVICE 0.5
TO RENEW HALDEX OIL AND OIL FILTER 0.5
TO SUPPLY AND FIT TIMING BELT AND TENSIONER 1
TO SUPPLY AND FIT WATER PUMP AND RENEW ANTIFREEZE 1
TO SUPPLY AND FIT MULTI-RIB BELT 1
TO FIT FRONT AND READ BRAKE DISCS (SUPPLIED) 2
TO RE-FIT ENGINE UNDERTRAY 0.25
TO FIT FRONT AND REAR TYRES (SUPPLIED) 1
TO SUPPLY AND FIT FUEL FILTER 0.5
TO SUPPLY AND FIT OFFSIDE SIDE LIGHT BULB 0.25
TO SUPPLY AND FIT OFFSIDE NUMBER PLATE LIGHT BULB 0.25
TO SUPPLY AND FIT WHEEL BOLTS 0.25
TO SUPPLY AND FIT BOTH FRONT WHEEL BEARINGS 4
TO SUPPLY AND FIT OFFSIDE AND NEARSIDE TRACK ROD ENDS 1
TO SUPPLY FRONT NEAR SIDE ANTI-ROLL BAR LINKS 0.5
TO SUPPLY AND FIT BOTH REAR ANTI-ROLL BAR LINKS 0.5
TO HELI-COIL REPAIR ON SUMP 0.5
TO SUPPLY AND FIT FRONT ANTI-ROLL BAR AND BUSHES 1
TO SUPPLY AND FIT BOTH FRONT BRAKE CALIPERS 1
TO SUPPLY AND FIT BOTH RETURN POWER STEERING PIPES 1
TO TOP-UP POWER STEERING FLUID 0.5
_____________________________________________________________________________________________________________
LABOUR FOR ABOVE £45 20.5 £922.50
PARTS USED
FLUID FILL? £6.50 1 £6.50
FLUID FILL? £11.10 1 £11.10
SPARK PLUGS £11.00 4 £44
CASTROL FULLY SYNTHETIC OIL 1/2 LITRE £3.90 8 £31.20
LUBRICANT £2.89 1 £2.89
HALDEX OIL £10.75 1 £10.75
HALDEX FILTER £24.29 1 £24.29
TIMING BELT £20.50 1 £20.50
TENSIONER £41.00 1 £41.00
WATER PUMP £30.50 1 £30.50
MULTI-RIB BELT £24.00 1 £24.00
FLUID FILL? £6.86 1 £6.86
SIDE BULB £0.85 1 £0.85
PLATE BULB £0.85 1 £0.85
WHEEL BOLT £1.80 4 £7.20
NEARSIDE TRACK ROD END £22.33 1 £22.33
OFFSIDE TRACK ROD END £22.33 1 £22.33
NEARSIDE FRONT ANTI-ROLL BAR LINK £25.59 1 £25.59
REAR ANTI-ROLL BAR LINK £17.06 2 £34.12
FRONT WHEEL BEARING £41.29 2 £82.58
FRONT ANTI-ROLL BAR £64.39 1 £64.39
ANTI-ROLL BAR BUSH £4.77 2 £9.54
HEATSHIELD CLIP £0.32 8 £2.56
OFFSIDE FRONT BRAKE CALIPER £74.00 1 £74.00
NEARSIDE FRONT BRAKE CALIPER £74.00 1 £74.00
POWER STEERING PIPE £72.96 1 £72.96
POWER STEERING PIPE £88.74 1 £88.74
POWER STEERING FLUID TOP-UP £3.60 1 £3.60
ANTIFREEZE 0.5 LITRE £3 4 £12.00
TOTAL FOR PARTS/MATERIALS AND OILS/LUBRICANTS £851.23
PARTS SUPPLIED BY MYSELF
BRAKE FLUID £25.08 1 £25.08
FRONT BRAKE DISC £40.78 2 £81.56
REAR BRAKE DISC £29.38 2 £58.76
FRONT BRAKE PAD £9.55 4 £38.19
REAR BRAKE PAD £5.27 4 £21.09
TYRES £62.59 4 £250.36
TOTAL FOR SUPPLIED PARTS £475.04
WORK NEEDED TO BE DONE AS SOON AS POSSIBLE
NEARSIDE FRONT WHEEL HUB CARRIER £196.36 1 £196.36
LABOUR £45 1 £45
TOTAL FOR WORK TO BE DONE £241.36
TOTALS
LABOUR £922.50
PARTS/MATERIALS £851.23
WORK NEEDED £241.36
TOTAL NET AMOUNT £2,490.13
TOTAL VAT AMOUNT £435.77
x £2,925.90
Ian Duncan
Re: Audi TT service
Post by renmure » Fri May 21, 2010 11:49 pm
Audi: Vorsprung Durch Big Bills :shock:
Think I will stick to the economy class car brands :blackeye
jen
Girl racer
Re: Audi TT service
Post by jen » Fri May 21, 2010 11:54 pm
renmure wrote:Audi: Vorsprung Durch Big Bills :shock:
a4drk
Re: Audi TT service
Post by a4drk » Sat May 22, 2010 12:14 am
I still think the biggest rip off was when I took my Boxster S into the Porsche garage in Edinburgh. (9 yrs old)
Basically, it had a major service done 18 months ago, but it had only done 2,000 miles since it.
So, they said all it need was an oil change.
OK, how much is that ?
£410 he replied....... and that didnt include an oil filter - he said you only change that every 2nd oil change :shock:
Anyway, didnt take his advice, left him & walked straight over to the parts dept & bought an oil filter. (£16)
then went to Costco & bought a twin pack of 2 x 4L of Mobil 1 oil. for £28
A local mechanic in Leith changed my oil & filter for me for £20 - took him 15 mins.
robbing gits - the bloody lot of them.
David
S2 Exige
Re: Audi TT service
Post by j2 lot » Sat May 22, 2010 12:29 am
Ian / Tut, feeling your pain. Nothing worse than spending so much money only to put it back to health and not have any modifications to show for the outlay. :(
