Droning sound?
cjm
Droning sound?
Post by cjm » Mon Aug 20, 2012 11:38 am
I have started to notice a new noise with my S2 111s. A dull droning sound just after I start the engine. If I jump in the car turn on the ignition I hear the fuel pump prime and stop, I then start the engine and after 5 seconds a dull droing sound starts. Its not very loud and it doesn't seem to change with engine revs or I can't hear it once the revs are above idle, the tone does alters breifly if I switch the headlights on and off. I did notice comments on SELOC about the rear alternator bearing drying out on the 111s due to the exahust postion, would this be early signs of that? Anyone had something similar or any thoughts on what to check?
edit - It does remind me of the sound my 205 gti fuel pump used to make when the tank was very low and it was running on fumes!
Colin
10-15 S2 Elise 111S
17-23 S1 Evora
Re: Droning sound?
Post by Shug » Mon Aug 20, 2012 11:45 am
Sounds very much like alternator bearing. Probably the best way to check is get in through the wheelarch, slacken the pressure on the alt belt (by loosening the alternator clamp and swinging it back) and spin the alternator pulley. Should be smooth as silk.
Kinger
Re: Droning sound?
Post by Kinger » Mon Aug 20, 2012 12:06 pm
I used to have a droning sound in my car too, got a divorce........droning gone !!!
Probably won't help in your case but worked for me !!!
Re: Droning sound?
Post by Dominic » Mon Aug 20, 2012 12:09 pm
Kinger wrote:I used to have a droning sound in my car too, got a divorce........droning gone !!!
:withstupid :damnfunny ...t'was an expensive fix that one!
Re: Droning sound?
Post by tut » Mon Aug 20, 2012 12:16 pm
Graham, think I will e-mail that onto Jan.
<BG>
Kinger
Re: Droning sound?
Post by Kinger » Mon Aug 20, 2012 12:19 pm
Go for it Tut, my inbox would be buzzing, but would put a smile on my face.
cjm
Re: Droning sound?
Post by cjm » Mon Aug 20, 2012 12:50 pm
Ha, no wife to worry about!
I'll have a poke about at the alternator when I get the chance.
Colin
10-15 S2 Elise 111S
17-23 S1 Evora
hendeg
Re: Droning sound?
Post by hendeg » Mon Aug 20, 2012 12:53 pm
cjm wrote:I'll have a poke about at the alternator when the chance.
That's what Graeme does now :wink:
Exige GT
