Cambelt tensioner
T8 YEA
Cambelt tensioner
Post by T8 YEA » Tue Jun 24, 2014 10:00 pm
Hello,
Would anyone be able to tell me if my 2000 S1 has an automatic or manual cambelt tensioner? Looking to change the belt but there is a few options on elise parts.
Cheers Al
Elise S1
Re: Cambelt tensioner
Post by woody » Tue Jun 24, 2014 10:38 pm
Is it a vvc or not?
T8 YEA
Post by T8 YEA » Wed Jun 25, 2014 12:29 am
I was under the impression that it is non vvc, how would I know just by looking?
Elise S1
Post by Dominic » Wed Jun 25, 2014 8:40 am
If its vvc it will be written on the plenum.
Post by woody » Wed Jun 25, 2014 10:41 am
Dominic wrote:If its vvc it will be written on the plenum.
Not always. However the plenum will be aluminium, there will be a bulge on the RHS of the head between the head & plenum with the VVC mech and a plastic casing on the end LHS end of the head with the additional pulleys and belt.
graeme
Post by graeme » Wed Jun 25, 2014 11:28 am
And a 111s badge on the back of the car.
/obvious
Post by campbell » Fri Jun 27, 2014 3:51 am
111s is not the differentiator for auto vs manual tensioner. Cue Robin to clarify.
Post by robin » Fri Jun 27, 2014 8:19 am
Correct,
Early K all used manual tensioner. All VVC and VHPD also use manual tensioner. Lots of tuned heads use manual tensioner.
Standard engines from these engine numbers onwards use auto tensioners (according to Eliseparts):
Engine Numbers;
18K4FJ31 153993
18K4FJ32 147263
18K4KL36 118709
18K4KL37 102149
18K4FL66 148135
18K4FL67 665464
18K4FJ78 151555
18K4FJ79 153785
18K4FJ89 146503
18K4FJ90 141815
Simplest solution is to look. You can remove the cambelt cover by taking off just the wheel arch liner and a handful of bolts that hold the cover on to the face of the head/block. You can leave the bottom cover on at this point.
If in doubt, post a picture and we'll tell you which one you have ...
P.S. 2000 K _should_ have an automatic tensioner.
Post by woody » Fri Jun 27, 2014 11:24 am
robin wrote:Correct.... All VVC and VHPD also use manual tensioner.
Which is why I asked if it was VVC.
Post by campbell » Fri Jun 27, 2014 12:11 pm
Sorry Woody. And Robin should not have said "correct", as I was incorrect there :-)
Was going on experience with my "cooking" K, where I wound up with manual tensioner belt by mistake. Took Robin a few head scratches to work out what I'd done wrong ;-)
Post by woody » Fri Jun 27, 2014 12:36 pm
campbell wrote:Sorry Woody. And Robin should not have said "correct", as I was incorrect there :-)
It's ok, knew what you meant. :)
Post by campbell » Fri Jun 27, 2014 1:00 pm
Good job someone did...!
