C/H oil.
C/H oil.
Post by tut » Thu Jan 15, 2015 3:31 pm
Good to hear that oil is now the cheapest means of home heating.
I order 2,000l at a time, Jan 2013 £1,370, today £730.
Re: C/H oil.
Post by renmure » Thu Jan 15, 2015 3:55 pm
I also get 2000, sometimes 2500 litres at a time and thought I was being smart by filling the tank in sept at 50p/litre. Now rushing to go through it so I can order some more cheaply
/manmaths fail. :)
Re: C/H oil.
Post by ed » Thu Jan 15, 2015 3:56 pm
I did the same :oops:
Re: C/H oil.
Post by tut » Thu Jan 15, 2015 4:04 pm
Difference is I order every 6/7weeks and have a 3,300l tank, along with a ton of coal very three weeks.
Dipper
Re: C/H oil.
Post by Dipper » Thu Jan 15, 2015 8:09 pm
is there a limit to how much you can store at a residential premises? we're building a house and so is a mate of mine. was thinking of putting in a couple large tanks and stocking up
Dipper
Re: C/H oil.
Post by Dipper » Thu Jan 15, 2015 8:22 pm
a quick google shows i can get a 15000ltr tank! :shock:
Re: C/H oil.
Post by renmure » Thu Jan 15, 2015 9:25 pm
tut wrote:Difference is I order every 6/7weeks and have a 3,300l tank, along with a ton of coal very three weeks.
Blimey, that's a lot. :shock:
We seem to average 4 tanks/yr so probably 10-11,000 litres. It was more when we still had the Rayburn. The 2 multifuel stoves stoves are more occasional use so I think a ton of coal does for the year. I did buy a chainsaw tho and am the proud owner of my own big pile of logs as opposed to buying them at the garage. Unfortunately I have less trees now :oops: :D
Re: C/H oil.
Post by tut » Fri Jan 16, 2015 12:25 am
Officially there is a limit of 2,400l for home use if VAT is charged at 5%. Above that it is classed as Commercial and VAT is taxed at 20%.
You might get some leeway from your supplier, but not for 15,000l in one go. However I see nothing to stop you ordering lots of 2,400 on the trot.
Mellow Yellow
Re: C/H oil.
Post by Mellow Yellow » Fri Jan 16, 2015 1:06 am
I have an electric system which uses water :lol:
Dipper
Re: C/H oil.
Post by Dipper » Fri Jan 16, 2015 8:32 am
tut wrote:Officially there is a limit of 2,400l for home use if VAT is charged at 5%. Above that it is classed as Commercial and VAT is taxed at 20%.
good to know. might need to stick with the wee tank until i have the completion cert then!
ClarkyBoy
Re: C/H oil.
Post by ClarkyBoy » Fri Jan 16, 2015 10:04 am
Bloody hell tut thats serious amounts of oil !
Mind you 'towers is a serious size!
We use about 1200-2000 litres a year, and like you Jim, i stocked up at 50p a litre, put in 1200 litres,
Considering a top up again soon, just whatever it takes to brim the tank.
Vanlife Sprinter
E30 318is / axle stand spec
987.2 Cayman S
[#]=///=[#] ‘88 Panda 4x4
BSA B31
MF35
Stiga Tornado
Many Bicycles
Dipper
Re: C/H oil.
Post by Dipper » Fri Jan 16, 2015 10:41 am
aye. stuff that Tut. thats a horrific amount of oil.
we're currently using 2-2500ltrs/year. thats in a 15yo 6 bed house with 4" of wool. the new house is a bit bigger but will have 7" of kingspan(equivalent to 14" of wool). i'm estimating that we'll half our oil usage :D
Re: C/H oil.
Post by BiggestNizzy » Fri Jan 16, 2015 11:27 am
Bloke at work has just changed over from oil to biofuel pellets and swears by it.
GraemeLotus
Re: C/H oil.
Post by GraemeLotus » Fri Jan 16, 2015 12:05 pm
I'd burn less coal if I had double glazing :blackeye
E92 325 C SE - Deutsch Verkehrsmitteln
Dipper
Re: C/H oil.
Post by Dipper » Fri Jan 16, 2015 1:21 pm
BiggestNizzy wrote:Bloke at work has just changed over from oil to biofuel pellets and swears by it.
he would though as he's just spent 20+k on a new system. we looked at it but it just didnt make financial sense, and thats before the price of oil more than halfed.
