Project V6 Elise
Bob vanM
Re: Project V6 Elise
Post by Bob vanM » Thu May 26, 2011 11:11 pm
I'm reading this with interest,
good efford !
some ideas we had ourselves :
make your own subframe and make it strong enough to cope with "big" torque and power :roll:
we are doing a 400/450 Bhp AUDI 2.0 with "some" tricks in an s1 Motorsport body :shock:
about the tight fit : make sure the engine mounts are stiff enough but also soft enough to stop the chassis multiplying the engine vibration noises
good job ! keep going !
[Click on the picture for higher res version - Robin]
tut wrote:They have just too many people posting on there, many with no idea about anything.
There are many good guys on there, our own Bob van M is one of them, but at times they are like vultures around a carcass, just want to put forward their own uninformed opinions or slate anything that does not agree with their tunnel vision. Engine conversions are one of their bêtes noires, so if you are outside of the Round Table you will have no chance.
Don't worry though, S_E will look after you.
<BG>
Post by robin » Thu May 26, 2011 11:25 pm
Bob, upload the image to photoshack, etc., and then link to it, or resize it so that it fits, or email it to robiniddon@googlemail.com and I'll sort it for you.
Bob vanM
Post by Bob vanM » Thu May 26, 2011 11:28 pm
you have Email,
thanks Robin :thumbsup
Post by tut » Fri May 27, 2011 8:33 am
That's why they wear cloggs and are called cloggies Robin, still in the stone age.
However they are good with dykes.
<BG>
Bob vanM
Post by Bob vanM » Fri May 27, 2011 3:47 pm
OI, Tut !
even with dykes we sometimes need another idiot to put his finger in a hole :wink:
I hope that you now finally realise why I gave you a pair of cloggs many years ago :mrgreen:
Woodsport
Post by Woodsport » Fri May 27, 2011 7:07 pm
Post #1 updated
ABZ-Elise
Post by ABZ-Elise » Sat May 28, 2011 12:40 pm
What are your driveshaft angles going to look like?
Kev.
1999 S1 Elise - For Sale
2003 E46 M3 - Sold
Woodsport
Post by Woodsport » Sat May 28, 2011 12:54 pm
ABZ-Elise wrote:What are your driveshaft angles going to look like?
Kev.
They will have about 2* of angle back to the hubs when viewed from above, less angle than the K series setup and perfectly level when viewed from the rear.
Post by Ferg » Sat May 28, 2011 7:01 pm
That clutch salve cylinder looks massive compared to the wee AP job on the Elise. Are you having to uprate the master cylinder?
Great read so far. :)
Woodsport
Post by Woodsport » Sun May 29, 2011 10:23 am
The Mr2 and Elise slave cylinders are a very similar size, must look bigger in the pics?
OlberJ
Post by OlberJ » Sun May 29, 2011 12:05 pm
Ha, is that not the selector shaft assembly? Slave cylinder's not in any of the pics.
Woodsport
Post by Woodsport » Tue May 31, 2011 7:04 pm
Post #1 updated
roadboy
Post by roadboy » Tue May 31, 2011 8:34 pm
I'd be changing those gear cables if I were you. They're not gonna last much longer.
/2p
Dan
SPS Automotive
Independent Lotus Specialists
Woodsport
Post by Woodsport » Tue May 31, 2011 8:47 pm
Why? What's wrong with them apart from the plastic outer cover split, the cables themselves are fine
roadboy
Post by roadboy » Tue May 31, 2011 9:21 pm
In my experience, once the outer plastic sheath splits it will not be long before the outer separates from the crimped end.
Will be a right pain in the arse when it falls to bits and its stuck in gear so makes a lot of sense to change it now whilst its in bits.
Up to you though obviously.
Where the subframe is marked on the left hand side in the gear linkage photo... is that marked to be cut out for clearance?
Dan
SPS Automotive
